Sponsored by: Real Truck
AC/Heater Blower Problem
Old Jun 23, 2011 | 07:05 PM
bryced_1's Avatar
bryced_1
Today i went out to my 2000 7.3 F350 this morning and i turn on my AC and nothing. I can hear the AC engaging and can hear it change from defrost to floor, etc. No matter what setting the fan setting is on it doesnt blow anything. How should I go about diagnosing what is broken?
thanks in advance!!
Old Jun 23, 2011 | 07:11 PM
74redone's Avatar
74redone
My 02 F350 had a bad resister for the blower motor($31.99 Autozone). My truck still had high speed but none of the others. When I pulled the plug out of the resister one of the blades had rusted off into the plug. I tried replacing the switch on the dashbut it didn't help my problem. IMO I would try the resister first.I'm not sure if this helps you or not but good luck!
Matt
Old Jun 24, 2011 | 08:43 AM
bryced_1's Avatar
bryced_1
Outstanding. It seems to be working intermittently now. Where is the resister at?
Old Jun 24, 2011 | 11:37 AM
74redone's Avatar
74redone
Blower motor box under the Hood on the passenger side. Good luck
Old Jun 24, 2011 | 11:40 AM
Lubbockguy1979's Avatar
Lubbockguy1979
It is a common ford issue. Had the problem with my 03 mustang, 06 mustanf and it is happening currently in my ford work van
Old Jun 24, 2011 | 04:37 PM
projectSHO89's Avatar
projectSHO89
A faulty resistor will not cause a complete loss of blower function - it will cause a loss of all speeds except HIGH.
An intermittent blower (in all speeds) is usually a bad blower motor due to worn out brushes.
Old Oct 9, 2011 | 05:12 PM
BC Powerstroke's Avatar
BC Powerstroke
I have replaced the resistor and blower motor and still no fix.
My blower goes to limp mode (very slow) after a long highway rides, say >2hrs regardless of running heat or AC. When I change the fan settings it simply stays on very slow.
Any suggestions would be appreciated.
90' XLT
Jul 30, 2022 02:22 PM
Antranger
1983 - 2012 Ranger & B-Series
Aug 9, 2016 08:41 AM
cookingguy
Jun 5, 2016 06:52 PM
clarkjg33
Jul 28, 2015 06:59 PM
SoCalAngler
19
Oct 15, 2014 09:53 PM
