Stalling after startup!!!
Old Mar 27, 2003 | 04:35 PM
klhinson's Avatar
klhinson
I need some assistance with keeping my E-150 running. I just replaced the head gaskets, and now that I have everything back together, the engine dies out after startup; everytime. The only way I can keep the engine running is to keep my foot on the gas. It runs great at higher speeds, but always stalls when I come to a stop. The timing and compression is great, new cap, rotor, wires, plugs, no vacuum leaks, new fuel filter. I am just out of ideas and do not know what to try next. Thanks for any reply and help.
A concern FTE.
Old Mar 27, 2003 | 05:14 PM
Ford_Six's Avatar
Ford_Six
Year and engine size?
Old Mar 27, 2003 | 05:49 PM
klhinson's Avatar
klhinson
It is a 1984 with a 302, 2 barrel<a href="http://www.motorhaven.com/"> carburetor</a>, all stock, 88,000 miles.
Old Mar 28, 2003 | 05:47 AM
Pkupman82's Avatar
Pkupman82
First of all are you getting black smoke out the tailpipe? If so you are running way too rich. If not you may have a weak fuel pump, Did you ever try changing the fuel filter, they can get clogged so bad that the engine will only run if you are on the gas constantly. Did you check for any vacuum leaks? The worst possible case I can come up with, your timing chain could be worn and jumped a couple teeth out of time.
