got a slight problem
Old Jun 23, 2011 | 11:39 AM
the1leadhead's Avatar
the1leadhead
4wd Low
95 f-150 flareside,4.9,5 speed.....started acting funny several months ago.....shuts off going down road,comes back on continues as if nothing happened....has left me stranded once.....now ,hard starts after being driven ond parked for a while, sometimes wont start....pressure on both fuel pumps checked ok,coil checked ok.....whats going on?
Old Jun 23, 2011 | 11:48 AM
ChristopherN's Avatar
ChristopherN
Any codes? When was the last time you changed your throttle position sensor? hen was the last time your PCV valve was changed?
Old Jun 23, 2011 | 04:38 PM
the1leadhead
4wd Low
checked codes,got 118-ECT -engine coolant temp. sensor.........522-not in park..lol......211-PIP,just what i didnt wanna see
Old Jun 23, 2011 | 05:57 PM
Bankrupter's Avatar
Bankrupter
DTC 211 indicates two successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
Loose wires/connectors.
Arcing secondary ignition components (coil, cap, rotor, wires, plugs, etc.).
CB/Ham Gear installed or in the past? that can trigger the pip also
Old Jun 25, 2011 | 07:54 AM
the1leadhead
4wd Low
well, changed out the PIP,seems as if problem is solved.....been driven 200 plus miles since,no problems......at 199,000 ,the"ol girl" is runnin like a new truck once again.......thanks for the input fellas
wooden79
2004 - 2008 F150
Oct 16, 2009 12:53 AM
maadman
Feb 8, 2008 05:09 PM
Johnny one
20
Nov 20, 2005 02:42 AM
lamarafronhe
Nov 14, 2004 06:45 PM
