Code P2285
Old Jun 21, 2011 | 08:33 PM
john11139's Avatar
john11139
Code P2285
I finally got my engine back in and running. Seems to run ok, but I am getting a code P2285, which is injector control pressure sensor low. Question. Where is this sensor located at? What do you have to do to get to it? I hope it is not where I think it is, back by IPR valve? Truck seems to run ok. How do I check this sensor? Or just replace it. What affect will it have on the truck?
Old Jun 21, 2011 | 09:07 PM
BLADE35's Avatar
BLADE35
can you monitor ICP and IPR
your IPR may have trash on screen ???
did you do anything to this sensor
how deep did you go in moter
what year
Old Jun 22, 2011 | 06:35 AM
john11139's Avatar
john11139
I had the engine out. One new piston, 2 valves and rod bearings. Cleaned screen on IPR valve when I had it out. Where is injector control sensor located at.
Old Jun 22, 2011 | 06:40 AM
npccpartsman's Avatar
npccpartsman
ICP sensor 03 motor is back under the turbo by the IPR valve. 04-07 motors it's on the passenger side valve cover--3 wire sensor. 03's are fairly prone to failure. 04-07's not much. Check the harness plug-in for oil contamination. If it's oily then replace it along with the sensor. Here are the ford and IH numbers for each.
03 ICP - 04 (pre 9/23/03) 3C3Z-9F838-EA 1845274C92
ICP pigtail 5C3Z-12224-A 1850712C91
Old Jun 22, 2011 | 02:06 PM
john11139's Avatar
john11139
Can you get to it without taking the turbo off?
Old Jun 22, 2011 | 02:13 PM
embry1123's Avatar
embry1123
yes, its not fun but it can be done. I did mine in about an hour.
Old Jun 22, 2011 | 04:14 PM
npccpartsman
Follow William's instructions here in the tech folder: https://www.ford-trucks.com/forums/8...ml#post7693493
Brian460
Mar 9, 2015 08:56 AM
TXHillCountry
Nov 30, 2014 10:53 PM
chiefn10
May 27, 2012 02:58 AM
BMXdad
Jan 5, 2010 11:18 AM
MUD BUGGY
Jun 2, 2008 12:03 AM
