Correct way to bolt down headers?
Old Jun 21, 2011 | 10:49 AM
Khauler's Avatar
Khauler
Puttin some new exhaust gaskets on my ford and was just wondering what is the best way to to bolt down the headers when putting them back on to eliminate any leaks....
Old Jun 21, 2011 | 01:14 PM
HIO Silver's Avatar
HIO Silver
Prepare all the bolts and washers by applying antiseize to the threads.
Loosely place the header in position and then slide the gasket btwn the head and the header flange.
Thread a couple of bolts to hold the gasket and header in place.
Thread the remainder of the bolts.
Snug all the bolts but do nto tighten.
Heres' the tricky part..... start tightening the bolts in such a manner that it applies even pressure on the header flange. You do not want to bend the flange whatsoever.. jump around as you would when installing an intake manifold or lug nuts to apply compression across the flange evenly.
You'll want the bolts snug but not "Gorilla" tight.. For example, stock exhaust manifold bolts' spec ranges from about 20 ft. lb to 36 ft. lb.
When completed, drive normally but for about every five run cycles (heating and cooling periods) go back and re-snug the bolts. You'll have to do this until the gaskets take their final crush.
Enjoy your leak free headers!
Old Jun 21, 2011 | 02:34 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
No torque wrench? I've found using a 1/4" drive ratchet I can get the torque in range. Never can get the torque wrench to all of them. I have checked this with a torque wrench. You may be stronger than me so results may vary. Locking fasteners will keep them from backing off. X2 on all the above.
Old Jun 21, 2011 | 07:15 PM
HIO Silver's Avatar
HIO Silver
Nope.. I don't use a torque wrench for precisely that reason - inaccessibility. I have found that the factory specs on stock manifolds are on the loose side and assumes the gaskets receive their final crush with the initial torque. In my experience (30 plus years) the "feel" gauge works better... again, tight but not gorilla tight. Re-tightening after repeated heat cycles has worked like a charm for me.
Old Jun 21, 2011 | 07:23 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Wasn't asking. Providing alternative for him if he has no torque wrench. Also been doing it for over 40 years.
Old Jun 21, 2011 | 07:55 PM
allwthrrider's Avatar
allwthrrider
I just went thru this on my 390, measure the ports on the header's & the exhaust port on the heads, go to the Dougs header website or you can search it on summit website & order the correct size, I went thru 3 sets of gaskets getting a pair that fit correctly or even better go to remflex.com
Old Jun 21, 2011 | 08:07 PM
The Incredible Sloth's Avatar
Why not just run lock washers instead of re torquing the bolts a second time? Seems to me that the main reason gaskets fail is the flange slowly settles and then the gaskets loses its squish. At least with lock washers there's less clamping force lost after everything settles down. Not endorsing the idea though just stirring the pot
+1 on the antiseize
Old Jun 21, 2011 | 08:16 PM
HIO Silver's Avatar
HIO Silver
But your post had a "?" Hence my conclusion. I understand your syntax now.. it didn't quite translate on the screen and is a pitfall of technology.
Stage 8 locking fastener hardware is fine. A few more bucks but I think it's a PITA with the tang and then the little E-clip. Regular lock washers? Sure, to each his own- Some headers come with them and some do not.
Old Jun 21, 2011 | 08:35 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
[quote=HIO Silver;10487751]But your post had a "?" Hence my conclusion. I understand your syntax now.. it didn't quite translate on the screen and is a pitfall of technology.
Stage 8 locking fastener hardware is fine. A few more bucks but I think it's a PITA with the tang and then the little E-clip. Regular lock washers? Sure, to each his own- Some headers come with them and some do not.[/quote
I should have been more precise with my answer. I did agree with your procedure. However, there is an exception. There are gaskets that you presoak in water, and take them to final torque before heating. If you try to tighten them once dry, they will crack like ceramic. These should be avoided in my opinion.
Old Jun 23, 2011 | 11:31 PM
orich's Avatar
orich
If old 1/4 header plate should be replaced. 5/16-3/8" are better this is one area every one has a little different way. Headers are one of those think that can last for a good number of yrs. before gaskets fail. And it not fixed in a timely matter your burn out the matting surface on the head which can only be fixed by removing and having it milled smooth again. To do it right. Their is some stuff called Therm o steel that works pretty you if you have the surface prep right. All gasket will end up just failing if head is burned out. So make sure the your heads manifold matting surface is good. Me,I like the Sanderson headers they use No Gaskets just high temp rtv..
orich
Old Jun 25, 2011 | 10:30 AM
Victor L's Avatar
Victor L
Remflex gaskets.
The only way to go.
DirtWorx
17
Nov 13, 2016 06:26 PM
das54
21
May 13, 2016 11:06 AM
ford351powr
Jun 3, 2011 08:42 PM
jlj6t
Apr 4, 2011 03:54 PM
olddude
Aug 29, 2001 08:13 PM
