PI intake temp sensor?
Old Jun 21, 2011 | 10:23 AM
ncon's Avatar
ncon
Hi guys, Anyone know where the stock temp sensor belongs on a Superduty PI intake?
I completed a NPI intake swap, and it looks like I may need to drill and tap this sensor either into the AL crossover section (same location as my NPI intake sensor), or into the upper hose elbow? Problem is my sensor is like 5/8 thread...I read on a f150 forum the PI temp sensors took a 3/8 thread?
thanks - Neil
Sipping through a slightly fatter straw
Old Jun 21, 2011 | 07:16 PM
galaxie641's Avatar
galaxie641
When I put a PI engine in my '97 the crossover had a plug that I pulled out and my stock NPI sensor threaded right in. Dead center right there below the TB.
Old Jun 22, 2011 | 10:28 PM
ncon's Avatar
ncon
The location must have moved from the intake manifold with the PI change, the 2003 superduty PI intake I installed had no plug tapped where I would have expected it. And also my lightning PI lower intake (on the shelf) is missing this sensor port.
Looking closer, the npi temp sensor thread is the same as a spark plug, and I happened to have that particular tap on hand...
So I tapped the elbow and works great. Note to others attempting this: don't get smart and put the hole on the flat spot inline with the manifold bolt cause then your screwed (good thing I had a spare elbow).
Ibleedspeed
1997 - 2003 F150
Feb 27, 2018 08:25 AM
Faber
93
Nov 27, 2016 04:13 AM
chopsieze
Modular V8 (4.6L, 5.4L)
Jul 26, 2016 02:21 PM
chopsieze
Johnlwlr
Modular V10 (6.8l)
Apr 19, 2011 03:39 PM
