Heavy load
Old Jun 21, 2011 | 10:05 AM
89idihauler's Avatar
89idihauler
Heavy load
So I have a full size 12ft in bed camper that I haul . And I'm thinking of getting the big double trailer hitch so it will extend out past the camper overhang so I can haul my sixteen foot flat bed with quads . How will the truck do with that much weight? Also I have air bags on
Old Jun 21, 2011 | 11:03 AM
ADTMan's Avatar
ADTMan
git 'r' done! That truck will pull your whole house to the lake if you wanted it to. I have hauled 16 thousand pounds of metal with my truck before. She grunted a little but she sure did one helluva job for me. That doesnt include the weight of the trailer either.
Old Jun 21, 2011 | 12:18 PM
RA31925's Avatar
RA31925
Just make sure your brakes are up to the task. Getting the load moving isn't nearly as important as being able to stop it safely. Consider trailer brakes.
Old Jun 21, 2011 | 02:15 PM
tjc transport's Avatar
tjc transport
i ain't rite
i used to pull 23,000 lbs all the time.
it always got there, just did not get there fast.
Old Jun 21, 2011 | 06:15 PM
Otahyoni's Avatar
Otahyoni
Make sure your hitch is rated for the load too. A lot of those extenders cut the weights down to 1/3 of the hitch rating...
Be safe out there!
Old Jun 21, 2011 | 10:34 PM
84-6.9L's Avatar
84-6.9L
Probably go with one of then there load distribting hitches, because of the long reach.
Old Jun 21, 2011 | 10:59 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I kind of miss my full size 12ft. slide-in camper I use to have, old heavy 1970's Shamrock camper.
Stock F250, single wheels, no sway bars, and no real air bags. Just some big rubber boots.
Sure was tippy in high winds.
Just over 5 tons on the scales. Never towed anything behind it with the camper on it though. I can't imagine a small flat bed trailer with a couple quads on it would make much of a difference...
Old Jun 21, 2011 | 11:16 PM
ADTMan's Avatar
ADTMan
No they just might walk all over the road though. Wont be able to see it either. Out of site, out of mind is NOT a good thing in this application. Might consider sway bars for the hitches on the second trailer. Going to have to splice into the trailer wiring for the second trailer too. Should be pretty simple for that one.
Hikingslo
30
Oct 28, 2016 11:49 AM
tincan1
All Things Towing
Apr 25, 2016 04:44 PM
Dirtbag
Jan 16, 2016 10:39 AM
TheFrog
13
Jul 25, 2014 07:58 PM
popatop500
Jul 5, 2009 10:53 PM
