ball joints DIY?
Old Jun 27, 2011 | 09:59 PM
I fish's Avatar
I fish
Originally Posted by 99expyTN
I took my Expedition to the Ford dealer today (big mistake) to have it aligned since I replaced the upper control arms. They called me back about 2 hours later and said the alignment was going to cost $270 because they needed to install a camber adjustment kit on the right upper control arm. Someone please correct me if I'm wrong, but I think all the "camber adjustment kit" is is an elongated washer with marks. I believe they use it with the bolt that attaches the upper control arm to the frame to move the upper control arm in and out to adjust the camber and/or caster.
Yea, the washers aren't cheap though, something like $40 per side at Advance Auto if i recall correctly. and yes, it just attaches to the upper control arm bolt.
Old Jun 28, 2011 | 06:19 AM
99expyTN's Avatar
99expyTN
Ok, I checked AdvanceAuto and they sell a Moog kit (part K8740) which includes new bolt, nut, washer, and cam adjustment kit (washer with off-centered hole) for $28.99. I guess with Fords markup that kit would probably cost $90. I should have installed one when I installed the upper control arms.
Old Jun 28, 2011 | 06:26 PM
alloro's Avatar
alloro
Yeah you gotta watch the dealers and their outrageous prices. Just so I don't have problems down the road, I ordered a pair of rear lower control arm to replace mine. I ordered the ones without the bolts and figured I'd go get them at the dealer. When he told me $96 for the set of of 4 bolts and nuts, I told him I didn't want the gold ones. He was less amused less than I was. Anyways, I surfed on over to the Bolt Depot - Nuts and Bolts, Screws and Fasteners online and got the set of 4 bolts and nuts for under $25. BTW, the bolts are grade 10.9 and 16mm X 90mm for anyone that needs them (after mid-1998, before that they were 14mm).
Old Jun 30, 2011 | 12:51 AM
99exp4wd5.4l's Avatar
99exp4wd5.4l
shouldn't I replace the the lower control arm bushings? I didn't see anyone saying they did.
YouTube - ‪F150 Squeaky Ball Joint Replacement‬‏
Ball Joint Replacement Video
Idler Arm Inspection
http://www.fme-cat.com/Docs/2215.pdf
Old Jun 30, 2011 | 10:37 AM
Methodical_1's Avatar
Methodical_1
Thanks for the video and link
tennesseex
Jan 31, 2017 09:04 PM
Nick Gearity
26
Aug 10, 2016 03:03 PM
sixty4chevrolet
May 1, 2016 07:09 PM
Boss_358
1983 - 2012 Ranger & B-Series
Apr 8, 2016 09:37 AM
boosteddsm
Jun 15, 2011 09:44 PM
