need answer asap!!!
Old Jun 20, 2011 | 09:27 PM
brokeisnojoke's Avatar
brokeisnojoke
need answer asap!!!
Closed knuckle dana 44 front and dana 60 rear matching. 4.10 gears. $300 should I buy them? 300 is for the pair. They are out of a 75 ford..
Old Jun 20, 2011 | 09:30 PM
bad12jr's Avatar
bad12jr
To put in what.
Old Jun 20, 2011 | 09:35 PM
oreocreaming's Avatar
oreocreaming
300 isnt bad, but thats a drum front brake iirc. it cost too much to swap it to disc. you can find a d44 HD 8 lug out of a 78-79 for 300-400 and a 10.25 rear for $100 and you have disc front and a great rear end.
Old Jun 20, 2011 | 09:36 PM
oreocreaming
also, that d60 rear wont have a vss so you cant run it in your truck since you have electronic gauges. if you lived close enough, ive got a d44 HD 8 lug front with disc and the vss 10.25 posi 4.10 gear rear for $500 for the pair.
Old Jun 20, 2011 | 09:37 PM
coreylasalle's Avatar
coreylasalle
i dont know if id put a solid 44 under a powerstroke
Old Jun 20, 2011 | 09:43 PM
oreocreaming
why not? the regular cab f250 would be a ttb d44. you'd be just fine if your not lookin to run larger then 35's and you dont go crazy off roadin it. but NO front drum unless you like free coasting down hills on a 4% or steeper decline or if you pull a trailer.
Old Jun 20, 2011 | 09:48 PM
brokeisnojoke
Thanks guys I think ill pass on it. I am in desperate need for rear diff parts. I only need the pin but will buy whole diff if that's all I can get. If I bought this set up. Could I get more than 300 out of it?
Old Jun 20, 2011 | 09:52 PM
oreocreaming
i wouldnt count on it. maybe 80-100 for the rear and 200-250 for the front if you dont mind holding onto it for a while. its all about waiting for the right sucker..... i mean buyer for that stuff.
Old Jun 20, 2011 | 09:55 PM
brokeisnojoke
Ya. Do you kno where I could get the pin for the rear diff. I have a trac lock diff but no pin. My pin in the stock diff cam loose some how and is now half the size it was lol
Old Jun 20, 2011 | 10:00 PM
oreocreaming
you could check ebay or try ford. you can also look to upgrade into a posi unit or a different locker. thats what your talkin about right? the pin for the oem locker?
Old Jun 20, 2011 | 10:12 PM
brokeisnojoke
Yes that's the pin. I was looking at a trac lock posi brand new for 350. Easy swap but don't kno if its worth. I need a new front axle also. I get passed 55mph and the front end hops like crazy!! Ball joints were replaced last year and tires have been balanced twice. No clue wat the cause is
Old Jun 20, 2011 | 10:19 PM
oreocreaming
how about some info on your truck. year, what f-series, what cab, 4wd im assuming... what tranny? what gears?
Old Jun 20, 2011 | 10:54 PM
brokeisnojoke
1995 f250 extended cab. Motor is a 96. E40d. manual transfer case. Dana 60 4.10 gears
Old Jun 20, 2011 | 11:29 PM
oreocreaming
d60? front d60 straight axle? cant be the rear cause thats a sterling 10.25
Old Jun 21, 2011 | 12:54 AM
Talyn's Avatar
Talyn
solid front 44 is good axle.
but its drum brake.
