Sponsored by: Auxito
1997 f250 Gauge problem
Old Jun 20, 2011 | 05:52 PM
zenrid's Avatar
zenrid
On my '97 F250 the gauges all seem to give strange readings after the vehicle warms up. When its started cold the Battery and Oil Pressure both read about mid level. Then after about 5min the truck gets warm and the Heat gauge shoots to the top, the oil pressure goes to zero, and the battery shows max voltage.
It did this when I first got the truck then the alternator died and I replaced it. The previous owner said the gauges worked fine until he replaced the alternator on the truck 2 years ago. I'm a little bit worried now since the truck has burnt out an alternator within 2 years.
My question is do you think there is a related issue between the gauges and the alternator or would you say they are separate issues and the alternator that burned out was just a dud from the start?
Old Jun 20, 2011 | 07:48 PM
Dave G.'s Avatar
Dave G.
You might look and see if all the ground straps are still there, and connected. Firewall to intake is a pretty critical part.
Dave
Old Jun 20, 2011 | 09:04 PM
zenrid's Avatar
zenrid
I checked the grounding it all metered out good. Any other suggestions?
Camper Special Gene
Jan 29, 2015 07:50 PM
ZombiePopper
20
Sep 13, 2014 10:41 PM
Stebs
Jul 28, 2012 12:03 PM
kneescraper
Jan 16, 2012 08:08 PM
90pioneer
Jun 4, 2011 09:51 PM
