Are they chromed aluminum? Usually the chrome gets pits in it and causes oxidation like that. Usually this is accelerated by de-icing chemicals/salt or brake dust. In the upper left it looks like a lot of brake dust buildup, which is quite corrosive to wheels. Its good to wash your wheels frequently to get rid of the road salt, chemicals, and brake dust to keep them in good condition.
I don't know if they are chromed. They are factory if that means anything. If its anything it going to be brakedust cause there isn't any road salt used alround here. Any advice on removing the rust? That might be brake dust your talking about but I think that's rust. That is a painted area on the rim. Why they paint that grey I dunno.
I really don't want to replace wheels. I'm open to treatment/refinish suggestion. Being aluminum is the rust going to damage/ weaken the wheel? As far as I can tell this is the only wheel effected.
Ok, those are painted/clearcoated aluminum. No, it won't affect the wheel strength. You could clean them up really good and try getting most of the stain off with buffing, but it won't be a cure and it will come back over time. Once they are neglected to that point, they can't be returned to new without stripping off the coating, polishing, and recoating them.
I'm in the process of polishing my 18" OEM wheels. I'm using Mother's "Mag & Aluminum Polish" and Mother's "Mini Powerball" with great results. I'm also using Turtle Wax "Polishing Compound & Scratch Remover" on the heavily stained areas of the wheels. I hand polished the center caps and they look like new. I found all of these products at Wal-Mart.
If not taken care of that stuff can be real hard to get off. I try to keep that stuff off the wheels. I will clean my wheels every month just so that stuff doesn't build up and bond to the wheel. Easy to clean off if you stay on top of it.
