Front Hub Dillema
Old Jun 19, 2011 | 10:12 PM
66CustomCab's Avatar
66CustomCab
Front Hub Dillema
Like an idiot, I forgot to torque the lug nuts after a brake job & hammered the studs through the hub. Fortunately the wheel stayed on (Thank God!)
Unfortunately, all I seem to be able to find are ones like the one pictured on the right, which are 1/2" 'too tall', have a "shoulder' for a pressed on drum, and a notch on the rim of the flange. All features mine don't have. They won't work on my spindles as the outer bearing would ride on the threads for the castle nut.
Mine damaged original is on the left.
I need a good used front hub for my 2wd '66 custom cab long bed with auto trans & 352 V8. Anyone parting out a likely donor?
Old Jun 20, 2011 | 02:17 PM
66CustomCab
Hmmm...Well, anyone even seen a hub that looks like mine on an F100? Perhap it's not a stock hub & spindle? It's not like I've seen a lot of them like some people on this forum.
Old Jun 20, 2011 | 04:26 PM
66f-100's Avatar
66f-100
I would be happy to give you one of mine after I do my disc brake swap. You might be able to find someone closer to you that has already done it.
Old Jun 20, 2011 | 04:43 PM
66CustomCab
That's very kind of you! I'm not sure when you plan on doing the swap, but if it's soon, I might have to take you up on that offer. However, this is my daily driver and I do need a replacement ASAP. It's kind of hard getting groceries on a motorcycle.
camodown
133
Sep 2, 2025 12:31 PM
sammie0126
Dec 21, 2016 12:24 PM
AIbandit
16
Jan 27, 2013 07:26 PM
66CustomCab
WTB - Parts & other
Jul 15, 2011 07:39 AM
ampslw
Jan 17, 2010 08:13 PM
