Need Help with Cruise Control
Old Jun 19, 2011 | 06:06 PM
ScotF150's Avatar
ScotF150
My cruise don't work and I'm trying to troubleshoot it. I don't have an owners manuel and can't look up which fuse supplys the cruise. If someone would be kind enough to look this up in their manual and pass the info along I would greatly appreciate it.
Thanks,
Scott
EDIT: I think I found it in an old post. Fuse # 13
Old Jun 19, 2011 | 07:30 PM
Swagtastic's Avatar
Swagtastic
If it's not the fuse check ALL your brake lights including the 3rd brake light, most cruise systems won't work with brake lights out.
Old Jun 19, 2011 | 07:59 PM
ScotF150's Avatar
ScotF150
Will do! There was power to the master cylinder and the switch tested OK.
Thanks for the reply,
Scott
Edit: All is well with the lights....done for the day.
Old Jun 20, 2011 | 12:02 AM
wallz's Avatar
wallz
Scot. You can download a free manual off one of the ford web sites. I printed off the pages that have the fuses and keep a copy in the truck as they come in handy. I don't have the link but if you search "manual" the link will come up.
If your horn doesn't work, then it is clock spring related. If your shift lever deosnt shift out of park then your safety switch on brake pedal. If the above work then it is either the switch on the end of master brake cylinder, which has a recall, or your cruise module. Try the switch, wiring on end of brake cylinder first as that one is only 20 or so compared to several hundred for cruise servo. The recall takes care of issues of X's burning after the wiring on brake cylinder leaks fluid and shorts out causes flames.
Old Jun 20, 2011 | 06:41 AM
ScotF150's Avatar
ScotF150
Wallz, thanks for the reply. Everything else on the steering wheel seems to be working OK. I tried the diagnostic and the buttons work and I can hear the servo cycle. I'll have to get another set of eyes to see if the cable is moving.
Thanks,
Scott
Old Jun 20, 2011 | 10:04 AM
ScotF150's Avatar
ScotF150
Cruise now working
Don't know what the problem was but after checking all the connections and running diagnostics the cruise is working. Thanks for the replies.
Scott
Old Jun 20, 2011 | 10:40 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
FYI...you can download a pdf version of your owners manual here...
https://www.fleet.ford.com/maintenan...ls/default.asp
Good luck and glad it appears to be working for you now.
Joe
scott53715
May 26, 2013 11:35 AM
bulletpruf
Feb 26, 2013 12:02 PM
powerstroker100
22
Sep 27, 2011 08:51 PM
edwardlloyd
2004 - 2008 F150
Dec 31, 2010 06:40 AM
scottjo
Jul 1, 2007 02:46 PM
