shorted my CPP wires, cruise not working anymore
Just as title says, I had the cpp wire jumped to work my cruise control but ended up shorting the paperclip on the firewall and now cruise isn't working, took the paperclip out and stripped the wires and soldered em together, checked some fuses, don't know which is for cruise, didn't check the under hood fuse box
Pretty pissed off at myself I should've soldered em in the first place, im thinking I fried something
What can I check?
What can I check?
****, and if it blew the pcm then what? the truck still runs great just cruise isnt working, could there be something in the cruise control circuit? maybe an inline fuse, I know the harness that connects to the sensor on the master cyl is new because of some ford recall
I tried doing the cruise control diagnostic and it didnt even go into diagnostic mode
The diagnostic sequence that I was following is listed below (posted by pops_91710 amoung others) I haven't gotten anything to work out of it yet, hopefully you will have better luck.
Try this test:
Diagnosing/Resetting the Cruise-Control operations:
1. fully engage parking brake. Make sure brake peddle is released.
2. Begin static portion of self test by pressing and holding speed control off switch.
3. Turn ignition switch from off to run. The cruise indicator on the instrument cluster will flash once to indicate the speed control module has entered diagnostic mode.
If the cruise indicator does not flash repeat steps 1-3. If the cruise indicator still does not flash, diagnose the cruise indicator.
4. Release the off switch
5. The cruise indicator will flash when each switch is pressed. While performing self test. Press each switch in the order described while observing cruise indicator for a flash. Note any switch activations that does not cause a flash.
Within five seconds of turning the ignition switch to RUN:
Press the on switch.
Press the resume switch.
Press the coast switch.
Press the set/accel switch.
6. NOTE: the on switch must be pressed within five seconds after entering the diagnostics mode or the speed control module will return to normal operating state and self-test must be repeated.
Flash Code Function Tested Possible Cause
0 Speed Control Servo Speed Control Servo Defective
1 Complete System
2 Stop Light Switch Circuitry Stop Light Switch Circuitry
3 Brake Deactivation Circuitry Brake pressure control
valve defective circuitry
4 Vehicle speed sensor Vehicle Speed Sensor Out of
range
5 Speed Control Servo Speed Control servo defective
Try this test:
1 Complete System
range
Here is a wiring diagram in PDF. You will find the CPP switch in the bottom right hand corner. Not much to it really.
