Overfilled engine oil
Old Jun 19, 2011 | 02:46 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Must have been day dreaming when I changed my oil. Changed it about 800 miles ago, the other day I thought i'd check the level. Pulled the stick out and it was overfull, I drained about a quart and a half out, now its right where it should be. Would that hurt anything?
Old Jun 19, 2011 | 02:58 PM
Firefighter 1406's Avatar
Firefighter 1406
I wouldn't think anything major. I have overfilled mine by a quart before with no negative reactions.
Old Jun 19, 2011 | 03:03 PM
Farmboypowerstroke
Thanks for the reply, I figured it wasn't going to hurt anything. Truck is still running fine. Just wanted to see what others thought though
Old Jun 19, 2011 | 03:21 PM
cj45lc's Avatar
cj45lc
I know a few guys that just dump the 4 gal in at oil change, they say they don't want to keep the qt or qt & a 1/2 around. Say they don't have any problems...IDK
Old Jun 19, 2011 | 03:36 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
4 Gal oil change here for the last 11 years with no problems.
Old Jun 19, 2011 | 03:41 PM
cj45lc's Avatar
cj45lc
That's what I was talking about, call me a dumba$$ but I just cannot make myself do it...lol
4EXTRDR's Avatar
4EXTRDR
Yup...same here on all 7 of 'em all the time...4 Gallons and shut the hood
Old Jun 19, 2011 | 05:53 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Haha I did this 2 days ago!! Now I feel better anyway leaving with Camper Tuesday.
Old Jun 19, 2011 | 05:56 PM
ToMang07's Avatar
ToMang07
As long as it is overfull from YOU putting a little too much, shouldn't hurt it. (A quart or less.)
If it's overfull because fuel is leaking into the block... Well...
Old Jun 19, 2011 | 08:41 PM
PwerStroke99's Avatar
PwerStroke99
My truck takes 14 qts. whats weird is when i used to use Shell Rotella, i could put 4 gallons in, now with Synthetic i cant. dont know why, unless the new filter is slightly smaller, but i dont think it is. I use Donaldson Oil filters, used to use Motorcraft
Old Jun 19, 2011 | 08:56 PM
Farmboypowerstroke
This time I dumped the whole 5 gallons in, and I was a little over a quart over full
Old Jun 19, 2011 | 09:03 PM
hotroddsl's Avatar
hotroddsl
I personally don't recommend overtopping oil level as it can create excessive frothing of the crankcase oil this has 2 negative impacts on the PSD 1. Heavy frothing in the crankcase inter fears with piston cooling oil jet spray potentaly allowing piston overheat and subsequent failure! 2. Heavily frothed oil is highly compressable when frothed oil enters the HPOP it is only pressurized to a fraction of it's required psi the same condition then is passed on to the HEUI Where it is only amplified, therefore it is not really a good idea to add that little extra, internationational, spent a long time getting the bottom end just right,so we could go nuts up top, try to remember that MAX means just that MAX!
Brittanysmith
Apr 6, 2017 02:47 PM
Glenn54
Oct 25, 2016 07:33 PM
EvanBly
Transit Connect
Sep 10, 2016 10:45 AM
kmcaprice14
Jun 9, 2013 06:29 PM
TheNomad
Oil & Lubrication
17
Oct 9, 2008 07:45 PM
