i have 2 parts compatabilty questions
so im wanting to get rid of my e4od out of my 92 f350 4x4 and swap in the zf5 out of my 88 f350 2wd but my question is will my transfer case from my e4od bolt to the zf5?
and my other question is i pulled the codes and 29 comes up witch is speed sensor so i replaced the speed sensor on the rear end and im still getting the code so im thinking its the pcom now so im wandering if i can take the pcom out of my 91 f250 e4od 7.3l diesel and swap them out and see if that fixes my problem?
On the Zf question the answer is no. You would have to dismantle the ZF and fit a 4x4 tailshaft and transfer case adapter.
On the PSOM question the answer is no again as your `91 does not have one.
Maybe try unplugging the RABS ECM and see if that helps (it should be behind the glovebox).
you CAN always swap in the zf5 and get a divorced transfer case. then you will be able to run a longer front driveline and clock it any way you need without having to worry about it being in the way at all. even be able to run a chevy tc with a chevy d60 (cheaper then the ford/dodge) with the passenger side drop.
so ive been calling around and google searching and cant find any buddy that will sell the 4x4 parts off of the 4x4 zf5 so does any buddy have the tail section and the main shaft that there willing to sell or could i do something like this
Classic Broncos .com - Tech: ZF Transmission into 66-77 Early Ford Bronco
coleman1
04-04-2011 10:57 AM
gunner360
07-24-2010 11:08 PM
gunner360
07-24-2010 11:07 PM
