OK, my son's 94 f-250 has the factory plugs under it for the trailer plug.I checked them with a test light and they have all the lights and brakes wired to them.I need to put on a new 7-way and would kinda like not having to cut and splice.Anybody have a source or a part#?
I have a new plug,I would like to keep the factory plugs off the chassis instead of cutting and splicing.It has the fact. tow package like my 95 Lightning and the brake controller was left in it by the previous owner.The factory gray plastic connectors are still under the truck at he rear.
Ford wiring harness has plug-in connector under the frame--just use that to hook up the new 7-pin. Or maybe I don't understand what you are trying to do.
The factory harness has two plugs with the trailer wires at the rear of the frame.I would like to find a pigtail to run from the plugs in the frame to the 7-way so I would'nt have to cut and splice the chassis harness .
