blowing fuses
Old Jun 21, 2011 | 04:52 PM
tonym1069's Avatar
tonym1069
blowing fuses
Hello all,
In my fifth wheel on the main fuses panel, I have two 30 amp fuses. Both continue to blow. I see vag refernces to the rectifier, but have not been able to find any shorts or grounds. I do not have a lot of knowledge on trailers, or there wiring. I but this trailer as a salvaged unit. So not much info came with it. Would like all the help I can get. If anyone knows any links to other sites or any good books to get, please tell me.
Old Jun 21, 2011 | 07:19 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by tonym1069
Hello all,
Okay, so to be sure I am on the same page, you are talking about the fuses in your converter panel and you are referencing the two fuses that are for polarity protection i.e. in the event the battery terminals are hooked up incorrectly the board in the converter won't turn to smoke. What converter do you have i.e. make and model number please.
Steve
Old Jun 22, 2011 | 07:19 AM
senix's Avatar
senix
subscribing!
Steve, maybe the battery terminals/wiring are reversed?
Old Jun 22, 2011 | 04:48 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by senix
subscribing!
Possibly. I always start there as the most common route to blown polarity fuses is from the battery side.
The points of consideration are any place the power to the converter on the dc end might be reversed and then the board.
For older model and smaller converter the fuses will be 30 amp, but most of the newer converters now use two 40 amp fuses. The polarity protection fuses are the ones in the converter that do not have visible leads to the them like the appliance fuses do. Really old converters do not have this protection.
Steve
Culvert
Nov 10, 2016 09:31 AM
misterbill11
Oct 16, 2014 03:47 PM
rb8484
Aug 18, 2011 11:01 PM
72soa
Oct 23, 2007 04:23 PM
Skottt
Electrical Systems/Wiring
Dec 28, 2001 11:22 AM
