Turbo Question
Old Jun 19, 2011 | 02:32 AM
10Sec5.0's Avatar
10Sec5.0
Turbo Question
I have a 92 7.3 that i am going to put a sidewinder kit on. i plan on pulling the motor and replacing the injectors, return lines, glow plugs and head gaskets. my question is: What is recomended for the head bolts? i thought about replaceing them but all i have found is ARP studs ($800). thats just too high for some bolts
Old Jun 19, 2011 | 10:30 AM
farmert's Avatar
farmert
The factory headbolts on the 7.3 are good for 12-15 lbs. of boost. I don't think you will get more than that from the sidewinder, without mods. I'd just use the stock headbolts.
Old Jun 19, 2011 | 12:30 PM
typefour's Avatar
typefour
Thats way to much for the studs, last ones I got were 450.00 shipped.
Old Jun 19, 2011 | 09:23 PM
oreocreaming's Avatar
oreocreaming
arp doesnt offer a 7.3l idi "kit" they have one for the 6.9l that WONT fit. they have 7.3l psd that also WONT fit. you can order em separately but thats about it. and as stated, no reason for studs unless you plan on running more then 15-16 lbs of boost or plan on running an exhaust brake. your better off saving that 800 bucks and getting a full exhaust, new injectors AND a rebuilt IP for the same money
Old Jun 19, 2011 | 11:21 PM
GHeTTo JOe's Avatar
GHeTTo JOe
ok when you guys say you need studs for ~15psi and more is that just so the head gasket stays together better?
Old Jun 20, 2011 | 12:17 AM
oreocreaming
Its to keep the head from pushing away from the block and causing the head basket to blow. Head bolts tend to stretch a lot more then studs will
Old Jul 2, 2011 | 01:42 AM
10Sec5.0's Avatar
10Sec5.0
thanks for the help. hopefully i get this done without too many problems
jtindale
Feb 6, 2012 06:11 PM
six6six
Aug 28, 2011 04:19 PM
Firemudder
Jan 7, 2011 03:24 PM
Third Coast
Sep 24, 2005 09:39 PM
First_Ford
Mar 17, 2005 12:11 AM
