Sponsored by: Auxito
got a miss......
Old Jun 18, 2011 | 08:17 PM
bcaughhorn's Avatar
bcaughhorn
got a miss......
02 supercrew f150.. 4.6 auto.. completly stock. 94k
i got a phone call at work.. the truck isnt running rite. trying to get good info from my wife on this is like pulling teeth. i call a friend. he went to look at it and scanned it. missing on startup. he pops the hood one of the coils is hanging out. so i buy a accel on the way home. i put it in. still missing. could the coil hanging out have caused the plug to go out?
Old Jun 19, 2011 | 08:15 AM
enriched&beyound's Avatar
enriched&beyound
Probably the other way around...plug blew out taking the coil with it maybe not, couldn't hurt to double check
accel coils...umm... are not the best choice....many bad out of the box.
have you rescanned the codes after the repair?
Old Jun 19, 2011 | 08:18 AM
bcaughhorn's Avatar
bcaughhorn
Haven't rescanned yet. Going to after work today
Old Jun 20, 2011 | 04:45 AM
bcaughhorn's Avatar
bcaughhorn
i rescanned it last night. still a mis fire on #6 cyl so i swapped the accel coil out with another to make sure it wasnt the problem . drove it around for a few miles and scanned again. still #6 misfire. i have a set of plugs sitting here but i couldnt find my plug gapper. ill pick one up today and change the plugs.
Old Jun 20, 2011 | 09:36 AM
93 mix 'n match's Avatar
93 mix 'n match
this seems probable. 1, dont coils have little screws on them to hold them in place? 2, coils just dont fall out....
does it drive like its missing or is it just the computer?
Old Jun 20, 2011 | 09:42 AM
bcaughhorn's Avatar
bcaughhorn
I just got the truck about a month ago. The screw wasn't in the coil. It has a noticeable miss when driving
Old Jun 20, 2011 | 09:47 AM
93 mix 'n match
if you pop the hood and listen to it, does it sound like a whooshing noise coming from the cylinder? do you know about the spark plug ejecting problem?
Old Jun 20, 2011 | 09:49 AM
bcaughhorn's Avatar
bcaughhorn
Never heard of that. I looked in the hole. It looked like the plug was in all the way
Old Jun 20, 2011 | 08:44 PM
matt06's Avatar
matt06
you will know if it spit out a plug you will definitely be able to hear it if it did advance auto parts has a kit to fix it. It comes with an adapter that will thread into the head and comes with a longer spark plug.
Old Jun 20, 2011 | 08:54 PM
bcaughhorn's Avatar
bcaughhorn
i figured it out. i feel dumb. i forgot how the cylinders were numbered on ford and didnt change #6. i guess it was a coincidence that the screw was missing from #2 and i changed it instead. the # 6 coil was firing but through the boot. and somebody changed half of the plugs. it had 4 autolites and 4 motocraft. they obviously knew nothing about gapping them. they ranged from .40 to .60
busflyer
Modular V8 (4.6L, 5.4L)
Nov 19, 2013 04:12 PM
Fordman49F1
2004 - 2008 F150
Jan 22, 2013 12:55 PM
bighighboy77
Oct 5, 2010 08:56 PM
Madathlon
Apr 11, 2005 04:55 PM
