54 4X4 posi
Old Jun 17, 2011 | 10:51 PM
kenjh's Avatar
kenjh
54 4X4 posi
ok ..I got stupid and took my truck out in the field to play..and found out it has one wheel drive..at one end or the other .open diff's I think it's called .so..can I get a posi or locker for a timkin axle ?? as mine are stock ..or should I give in and not destroy the vintage axles and install late model axles and lose the originality of the truck..I already have a dana 44 front on the shelf.. a rear should be an easy swap..but...right now it is 95 % stock ..it's not a show truck and never will be,,
Old Jun 18, 2011 | 04:35 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Ken - I don't see any way to convert your Timkens to LSDs. Swapping in other axles is possible, especially at the rear. On the front you'll have an issue making sure the old drag link lines up with the axle's steering arm. Plus, you've now gone to the expense of having those 19.5s made with the 6 x 7.25" pattern. You'll never find donor axles with LSDs having that wheel bolt pattern. Stu
Old Jun 18, 2011 | 08:51 AM
kenjh's Avatar
kenjh
one more reason I am sitting on the fence..new 19.5s on the rear..stocton is starting up again..and my younger brother has a suzuki that had to pull me out ..clay and street tires are a good way to learn humility....so ..stay with the Timkins ..and outa the field and keep her stock , you think..??
Old Jun 18, 2011 | 09:05 AM
tinman52's Avatar
tinman52
Welder User
Somehow I don't see your truck as an off road racer.....more like a tank that keeps going when the chevy's wimp out. I wouldn't change a thing.
Old Jun 18, 2011 | 09:42 AM
kenjh's Avatar
kenjh
so that's 2 for keeping her stock... maybe I should put a winch on her .so she can haul herself outa the mud..not a lot of choice in off road tires in 19.5...
Old Jun 18, 2011 | 11:33 AM
mOROTBREATH's Avatar
mOROTBREATH
I'm actually extraordinarily surprised that these trucks didn't have some kind of locking or limited slip diff.....at the very least an option. But no. ...You can't possibly tell me that those old farm roads didn't get muddy as hell.
Old Jun 18, 2011 | 02:15 PM
Old F1's Avatar
Old F1
Um-hum ?
Limited slip and especially locking differentials and especially early locking differentials work great until that greasy corner comes up (fast) and things don’t steer quite the way they should, actually they don’t steer at all, straight ahead into the rhubarb!
Old Jun 18, 2011 | 05:30 PM
kenjh's Avatar
kenjh
BUT I like rhubarb.....and don't you stear with the throttle ??
f150light
Aug 20, 2012 12:14 PM
Dutter
1983 - 2012 Ranger & B-Series
Mar 14, 2011 03:04 PM
dads truck
Oct 10, 2008 07:11 PM
wood4d
Jun 5, 2006 11:09 PM
bbtkd
Aug 30, 2004 09:36 AM
