Automatic column linkage
Old Jun 17, 2011 | 08:57 PM
droppedf100's Avatar
droppedf100
My truck was a 300 6/ 3 on the tree when I bought it and I did a bbf/ c6 swap with a B&M Pro stick floor shifter. I want to put a column shift in it now but not sure what all I will need. I have an automatic steering column for it and the lever appears to be on the trans. Is it just a linkage from the column to the trans? Its a 2wd. Any pics would be greatly appreciated.
Old Jun 18, 2011 | 04:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
It's a simple linkage, just a single rod from the arm on the steering column to the arm on transmission.
Here are a couple of pictures from my project. The first shows the shift rod going down from the steering column. The second is after the cab was removed. it shows the rod connected to the trans.
Old Jun 18, 2011 | 05:24 PM
droppedf100
Perfect man thanks. They have one at the u pull it ill grab it tomorrow. Ill have to make the reverse lights work though since it was a stick truck originally. Is the switch in the column or on the trans? I already have the reverse light wires ran to the aftermarket shifter.
Old Jun 18, 2011 | 05:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0
73-77 the neutral start/back-up light switch is on the column, under the dash just in front of the firewall. On 78-79 the switch is mounted on the trans, the shift arm goes through the switch.
Old Jun 18, 2011 | 10:51 PM
droppedf100
Yeah its a 79. Anyplace that sells them? All the trucks in the u pull it have the motors pulled.
Old Jun 19, 2011 | 09:11 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You should be able to get them at any parts store. Most aftermarket suppliers still have them, NPD (FTE sponsor), LMC, Rockauto (FTE sponsor) has them too for around $65.00. I have seen them for up to $100.00, so it pays to shop around.
Old Jun 19, 2011 | 12:11 PM
jim collins's Avatar
jim collins
Just bought one at NAPA, I don't remember the cost ,just put it on my card.
