A/C blows from dash to defrost when accelerating
Old Sep 27, 2000 | 07:57 AM
murrman's Avatar
murrman
The A/C blows from dash to defrost when accelerating air temp remains cold, and it doesn't matter on fan speed. Think it's a vacuum prob, but not sure where to start!
Mark
'93 F-150 XLT, 5.9L, 4x2, A/T, Factory A/C
Old Sep 27, 2000 | 10:29 PM
nitro94's Avatar
nitro94
This system will have a vacuum line coming off the intake going towards the firewall and thru to the control panel with a vacuum reservoir connected inline. Will sometimes tee off and also supply vacuum for cruise. You will usually find the problem under the hood in these lines. Is possible that break could be under dash where they route thru to the panel or a bad panel vac. switch or leaking vacuum door motor.
Old Sep 29, 2000 | 11:03 AM
murrman's Avatar
murrman
Cool... I'll check it out.
Thanks
Old Sep 30, 2000 | 01:13 PM
tominator's Avatar
tominator
I'm unsure of the part #, but Ford makes a valve that just goes into the vacuum line and is designed to prevent loss of vacuum in the dash controls. It is not model specific.
Check with your dealer. A sharp parts man will know what you're asking for.
Old Dec 19, 2000 | 03:34 PM
fordiesel69's Avatar
fordiesel69
I had the same problem with my 85 Grand Marquis. It was a broken vac line under the dash. I fixed it once and it did it again next year. I decided to live with it. Have fun finding the broken line!!!!
Old Dec 19, 2000 | 03:39 PM
fordiesel69
pcdocta
43
Mar 19, 2017 04:16 PM
jbedsole23
Mar 11, 2014 06:25 AM
mshargrave23
Sep 15, 2013 12:02 PM
shakebaker69
1997 - 2003 F150
Sep 3, 2013 06:13 PM
claycomotrucks1991
May 27, 2009 07:04 PM
