I just bought a 2002 F250 4x4 diesel it has LT32560R18s on it. It is rubbing just a little inside the rear in the middle of the fender wells when I make a sharp turn. My question is will a 2.5 leveling kit give me enough clearance? If so what kit do you all suggest if not what do you all suggest?
So they are rubbing in the rear fender..or in the rear part of the front fender?
If you are talking about front rubbing then as an example that could help, I have a friend who has the leveling on his 04 F-250 4x4 diesel and has the same size tire only with 16's and has some scrubbing on the leafs at full lock.
I think the leveling would fix the fender rubbing but you'll most likely get it minor somewhere else. The rubbing could also have to do with how wide the tires/rims are as well.
