Sponsored by: Kumho
Leveling kit?
Old Jun 16, 2011 | 08:17 PM
Hardcase_Ford's Avatar
Hardcase_Ford
Leveling kit?
I just bought a 2002 F250 4x4 diesel it has LT32560R18s on it. It is rubbing just a little inside the rear in the middle of the fender wells when I make a sharp turn. My question is will a 2.5 leveling kit give me enough clearance? If so what kit do you all suggest if not what do you all suggest?
Old Jun 16, 2011 | 10:36 PM
lovestrucks's Avatar
lovestrucks
So they are rubbing in the rear fender..or in the rear part of the front fender?
If you are talking about front rubbing then as an example that could help, I have a friend who has the leveling on his 04 F-250 4x4 diesel and has the same size tire only with 16's and has some scrubbing on the leafs at full lock.
I think the leveling would fix the fender rubbing but you'll most likely get it minor somewhere else. The rubbing could also have to do with how wide the tires/rims are as well.
Old Jun 17, 2011 | 10:49 AM
Hardcase_Ford
It's the back of the front inside fender it's plastic. The width is a problem and how tall they are. I'll post a picture.
