'93 F250 2500rpm idle
I do not know if this will help you, but my truck idle's at around 2000 rpms. When I got it the seller said that was normal, bull----. I replaced ever sensor, upper intake gasket, vaccuum hoses, check codes and it stills does it. I have been all over the internet and find people with the same problem but no answers. What I discovered about a month after I got it, if I hit the gas (rev the motor for a brief second) right when the motor starts running, the idle goes down to normal about 98% of the time. If it still idle's high I just repeat the above step. I been doing this for 2 1/2 years and 20,000 miles. I think mine is the computer, but I am to cheap to replace it. I figure I just keep driven it until it breaks down. It cound also be one of the new sensors I replaced was bad when I got them.(autozone brand)
I have the same problem, not sure exactly what the idle is since its a 94 but its way too high. I have unplugged the iacv so its not so rough on it. Also having trouble with it shifting late and hard, im wondering if it is my pcm since it also wont return any codes. If anyone has any ideas on this it would be very appreciated, thanks.
1978fordf250
03-19-2011 05:22 PM
