VSS
Old Jun 16, 2011 | 07:23 PM
brokeisnojoke's Avatar
brokeisnojoke
Exclamation VSS
my spedometer recently quit working and transmission is shifting at odd times, mostly late. it threw the vss malfunction code. i treplaced the vss on rear diff cleared the code and it continued and threw the code again. any suggestions? could it be pcm malfunction? motor is a 96' truck is 95'. i need help bad!!thanks
Old Jun 16, 2011 | 07:33 PM
helifixer's Avatar
helifixer
where did you get the sensor? oem or aftermarket?
pull it and check it.
I have removed new sensors that were manufactured too long and the ring in the rearend destroyed it.
also check wiring especially from the sensor to the frame.
Old Jun 16, 2011 | 07:59 PM
brokeisnojoke
i got the sensor from advanced. they wont replace it bc it was installed. i may buy another tomorrow. i have checked all exposed wiring but did not want to go through it al unless necesary. thank you for the reply
Old Jun 16, 2011 | 08:21 PM
427 fordman's Avatar
427 fordman
Go to ford for the sensor. I've heard of quite a few parts store ones not working.
Old Jun 16, 2011 | 09:13 PM
kupiec20's Avatar
kupiec20
same thing happen to me. it ended up being the VSS pigtail
Old Jun 16, 2011 | 09:28 PM
gatormccluskey's Avatar
gatormccluskey
I had a 97 f-250 7.3. the samething happened. I replaced the VSS sensor. Two days later the samething happened. I pulled the sensor again and it had metal on the sensor. I pulled the cover of the rear end and washed it out with fuel. I got a speaker magnet and put it in the rear end housing to catch the metal if anymore appeared. Replaced the oil. It is still running fine.
Hope this helps.
Old Jun 17, 2011 | 06:33 AM
DIYMechanic's Avatar
DIYMechanic
Is this an F series or an E series?
Old Jun 17, 2011 | 08:11 AM
brokeisnojoke
I will try all those suggestions. Thank you. It is an f series 4x4 auto with manual transfer case
Old Jun 19, 2011 | 09:27 PM
brokeisnojoke
pulled rear end completley apart. my cross pin was loos and shaved about half the size. i have new diff and gears but need a pin
bduemig
May 14, 2014 10:20 PM
BuckHammer
32
Sep 4, 2013 07:52 PM
95350PS
Aug 6, 2013 08:44 PM
Forced347sn95
Feb 9, 2009 05:14 PM
Shanemh
16
Feb 10, 2008 06:32 PM
