Vehicle Speed sensor
Old Feb 7, 2008 | 11:09 PM
Shanemh's Avatar
Shanemh
Anyone familiar with the VSS. My truck just threw a check engine code P0500 which is a VSS malfunction. At first I thought the tranny had gone, the overdrive button was flashing and it was holding the revs way longer before shifting and then when it did shift it was a real jerk. Then when I did a bit of research I found eveything was pointing to this VSS. The article I was reading said symptoms include irratic shifting, speedometer and oddometer stop working too. All this was what I was getting., Anyway, I am hoping this is not a big job. Where abouts is the VSS in my vehicle and is it a big deal to change?
Thanks, Shane
Old Feb 8, 2008 | 02:21 AM
TexasGuy001's Avatar
TexasGuy001
Its should be easy to change. On my truck it is located on top of the rear end. It also runs the rear abs. When you go to get one you will probably be better off asking for the abs sensor, otherwise the parts store will probably try to sell you the VSS for an older truck.
Old Feb 8, 2008 | 05:30 AM
tfowler306's Avatar
tfowler306
The VSS sensor is on the end of the speedomoter cable where it plugs into the trans. If you will crawl under the truck and look up at the tail shaft of your tranny @ aproxamitaly the 11 o-clock position (on the tailshaft) you should see the main body of the spedo cable along with a two wire plug on top of that cable body. where the two wirs plug in that is the VSS.
Old Feb 8, 2008 | 05:39 AM
jroehl's Avatar
jroehl
The speedometer cable goes into the tranny in pre-'92 trucks, but they still have a VSS in the pumpkin for the RABS. '92+ trucks use the VSS for everything--speedo, odo, tranny control and RABS. The OP has a '96 listed in his sig.
Jason
Old Feb 8, 2008 | 05:43 AM
tfowler306's Avatar
tfowler306
OK sorry about the miss info....
the 96 4x4 F150 I changed out the TC gasket on last week had the the spedo cable with VSS on the tail shaft of the TC.
I guess thay are just not all the same.
Old Feb 8, 2008 | 07:34 AM
jr32560's Avatar
jr32560
it should be on the rear-differential-believe they started in 90-is your speedometer still working??-if it's affecting the trans may be the speedometer-no allowing the vss signal to go to the ecm-had this problem twice on E250-
Old Feb 8, 2008 | 07:39 AM
tfowler306's Avatar
tfowler306
Wow I learn more and more every day I read things here.
Old Feb 8, 2008 | 07:56 AM
subford's Avatar
subford
The VSS on the TC of the 96 4X4 is for the Electronic Shift and is not connected to the Speedometer or PCM. It also has nothing to do with shifting the transmission. On these Trucks you also have the VSS/ABS sensor on the rear end for the Speedometer, ABS, and the PCM to shift the Transmission if it is has an Automatic Transmission.
Old Feb 8, 2008 | 10:16 AM
Shanemh's Avatar
Shanemh
Yes, its a auto tranny and the speedometer is not working also. Thanks everyone for great info. I am still a little confused. I am not very mechanically minded although I am getting better. What does all this mean, am I looking at a big expensive job?
Old Feb 8, 2008 | 10:34 AM
subford's Avatar
subford
The sensor is on the rear end is held in by one bolt and has a two-wire plug on it.
The VSS/ABS sensor is located top center of the big round thing in the center.
All of that said it could be other things beside the VSS/ABS sensor.
Could be the sensor, tone ring, plug, wiring or the PSOM or fuses to the PSOM.
The wiring runs from the sensor to the PSOM and is "T"ed off (spliced) to the ABS Module.
If it is the tone ring you may have other rear end problems also.
If you take it to Ford it could be about $500.00 give or take a hundred.
Old Feb 8, 2008 | 06:17 PM
jr32560's Avatar
jr32560
hey subford you think alldata .com-could help him?? I know the codes are very vague -but they do give a bunch of different tests to analyze the problems-on mine was like 30 or so-took about 15 to figure it out-and most times you need 2 people!!!
Old Feb 8, 2008 | 06:56 PM
subford's Avatar
subford
I do not know anything about alldata other than they are not free.
Old Feb 8, 2008 | 07:11 PM
quicklook2's Avatar
quicklook2
i do not think alldata will help here.
libraries in my area have it for free.
try the libraries in your area.
jr32560's Avatar
jr32560
no not free- but they helped me loads before I found this forum-was well worth the money spent-$35 for one year-$300 in parts -verses $3200.00 to rebuild the trans
Old Feb 10, 2008 | 04:40 PM
Shanemh's Avatar
Shanemh
Hey subford, thanks for helpfull inff. I am gonna try locate this. Where exactly is it and what am I looking for?
