Speedo bounce
Old May 13, 2014 | 01:16 PM
bduemig's Avatar
bduemig
Speedo bounce
I am getting a very small bounce in my speedometer at 60 on up, enough that you can feel a slight change in vehicle speed. I changed the VSS but it got a little worse. It also threw a VSS code. Put in the old VSS back in and it worked as it did before replacing it. Speedo also reads 3 mph high at 65 and increases as speed goes up.
Any ideas what my else may cause this?
Old May 13, 2014 | 08:32 PM
madpogue's Avatar
madpogue
If it's still fluctuating, check the tone ring in the diff. Crud between the notches will do that. If your diff fluid is old and ooky, this can happen.
Speedometer error is most likely a function of tire size. What size are you running?
Old May 13, 2014 | 08:48 PM
bduemig's Avatar
bduemig
I am running size listed on the door sticker. I have also calculated the circumference and changed the setting with no luck.
Old May 14, 2014 | 10:20 PM
bduemig's Avatar
bduemig
Changed the gear lube (it did need it), cleaned the tone ring and reserviced. The bounce is a little less noticable but it still bounces a little.
Rumble phish
2004 - 2008 F150
Jun 5, 2019 04:12 PM
metru
Nov 8, 2017 09:26 PM
Trickedout420
Mar 14, 2007 04:18 PM
karenj
Jun 16, 2004 08:38 AM
Greg250
Feb 20, 2004 03:19 PM
