Frame Question
Old Jun 16, 2011 | 01:37 PM
dpisa's Avatar
dpisa
Frame Question
I have a 1991 F-150,Can any1 tell me if i could use the frame from a 1985 dually for my 91? Wondering in NY
Old Jun 17, 2011 | 07:54 AM
03dsglightning's Avatar
03dsglightning
Dullay fram should be the same
Old Jun 17, 2011 | 09:22 AM
jokerforever's Avatar
jokerforever
If you have the same configuration, regular cab/long bed-crewcab/short bed, whatever, then I would think (don't know for sure) that you could use a 91 body on an 85 1-ton frame. Until the charge to the SuperDuty/light duty platforms in 99 Ford used the same bodies for the F150/F250/F350 lines. There will be nothing from your half ton chassis that will be usable other than the body. The 80-86 trucks are considered 7th gen and the 87-91 are 8th gen. Swapping parts between generations, especially something as major as a body, can get a little tricky but I know from experience that there wasn't that may changes between the two. Tread lightly but I say it could be doable.
Showpanther
Sep 28, 2012 08:00 PM
Kalve
Jun 7, 2011 09:24 AM
mlevario99
13
Jul 10, 2007 03:03 PM
grace553
Jun 27, 2007 01:43 PM
gensis1000
May 28, 2000 12:47 PM
