fuse panel
fuse panel
my under dash fuse panel melted a connector damaged fuse panel.
replaced the fuse panel and was trying to identify the plug and what its functions are?
replaced the fuse panel truck starts and drives, seems like it in limp mode
truck is a 2002 f 350 4x4 with a 7.3 diesel automatic it has air conditioning but NO power windows locks or mirrors.
Finger is pointing to where power lug is on front side of fuse panel.
there was 4 brown and 2 green wires that went into the connector. truck doesn't have working taillights or interior lights currently as well.
im trying to figure out what the burned out portion of the fuse panel in my picture did what does it run, operate or function.....
google search produces to much misinformation,
I was hoping some one here has already been down this road with the fuse panel and would have a idea of what my picture show's burned out and what it does.
the plug that was damaged is still not there or plugged in , so I need to find a plug/ connector and how its gets wired and or wire the wires to power or ground whatever is appropriate that are not currently hooked up. I have tested the wires and they all seem to be power leads or possibly grounds? so that why i was asking if anyone knew what that portion of the fuse panel controls???? help help help .
perhaps those wires do something with the VSM? would that cause a limp mode with the tranny ?
all my dash gauges seem to be working and reporting as they should .
The following users liked this post:
bjmayberry2
09-19-2018 12:53 PM
