air in lines
Old Jun 15, 2011 | 01:23 AM
zakk's Avatar
zakk
air in lines
so is there any trick to find where the air is getting in the lines. im pretty sure its not the return lines because i just replaced those a few months back. its a pretty bad leak after awhile of driving my truck boggs down and dies. it only did it on the front tank for a day or so but now it does it on both
Old Jun 15, 2011 | 01:29 AM
axel 56's Avatar
axel 56
I would be looking at the factory fuel lines that go to the tank and where they conect and the line that is on the sucktion side of the lift pump. It sounds like you are pulling air into the system and these are a good place to start.
Old Jun 15, 2011 | 01:34 AM
zakk's Avatar
zakk
if it was leaking from one of the lines on one of the tanks would that cause both tanks to not work?
Old Jun 15, 2011 | 02:47 AM
axel 56's Avatar
axel 56
No it would not wen mine sucked air it was just the one it would run fine on the other tank dose it run ok at idle and just act up wen driveing it could be the lift pump maybe but if its air I would be looking st the lines you know rusted or dented
chefcharles
Feb 7, 2014 11:52 PM
santeeford
Jul 26, 2013 08:29 PM
deaninkc
15
Nov 9, 2012 09:40 AM
shameless
Apr 3, 2009 12:09 AM
