more fuel line issues
Old Apr 1, 2009 | 10:14 PM
shameless's Avatar
shameless
so, after replacing the fuel pump, all fuel lines, filters, and cleaning out the sending unit, we're still having fuel issues. it runs at idle, then after driving it for only a short time, it dies and the fuel filter is emty. it looks like its sucking air into the filter but we dont think theres any holes anywhere in the lines. (again, new lines, rubber and steele) lol
we're pretty sure it needs a new alternator, but, can the two be related somehow?
This thing has us pretty stumped.
Old Apr 1, 2009 | 10:46 PM
fmc400's Avatar
fmc400
MSEE
When it dies, how easily does it start back up? The next time it happens, pull the air cleaner off and pull the throttle back and see if the carburetor has any fuel in it.
Old Apr 2, 2009 | 12:17 AM
mattjensen's Avatar
mattjensen
I was also having this problem, the truck would run great when there was fuel in the bowl of the cab, then when it ran out the truck stopped. Make sure your bowls are staying full, check the needle valve and make sure it works properly. To solve my problem i replaced the entire fuel line from the tank to the pump, i used an electric pump, and made sure there was no leaks and also rebuilt the carb. Truck finally runs great now, finally.
Old Apr 2, 2009 | 10:32 PM
shameless's Avatar
shameless
we're haveing issues with the charging system, and, the fuel system. installed a new alternator, nothing changed, and I'm replacing the little condenser box tomorow.
also, what are the odds that the lobes on the crank are run down enough that theyre not making enough connections to the pump?
Old Apr 2, 2009 | 10:57 PM
75F350's Avatar
75F350
If you have a vent problem, your tank can be full and the line will run dry. The empty fuel filter symptom can be a faulty fuel cap, or faulty vent.
put a gauge on the discharge side of the pump to verify fuel pressure and verify the volume. IF it runs out of gas after a short period of time, then you have to keep looking at the supply.
Old Apr 2, 2009 | 11:07 PM
shameless's Avatar
shameless
we've been trying it without the gas cap on, still the same symptoms. we thought maybe it'd be a vent problem so we took the gas cap off and left it off while troubleshooting.
Old Apr 2, 2009 | 11:12 PM
75F350's Avatar
75F350
Do you have a loop or a high spot in the fuel line somewhere? If the supply does not flow free, then the pump will starve. The pump should not have to create suction, as it should have a decent supply of fuel at the line.
You will then have to verify the discharge side of the pump to verify that the pump is functioning properly, and the eccentric is functional.
Old Apr 2, 2009 | 11:15 PM
shameless's Avatar
shameless
is there a gauge I can get to check that?
Old Apr 2, 2009 | 11:22 PM
75F350's Avatar
75F350
Sure there is, even the chain auto parts stores have them. It will have to be installed in series with the existing line, but a simple 'T' will do the trick. Watch the gauge once you getit running again, and see what changes the pressure goes through as the engine runs. Notice how much time it takes for this problem to occur.
Old Apr 2, 2009 | 11:34 PM
shameless's Avatar
shameless
does that go on between the pump and the motor, or between the pump and the tank?
Old Apr 2, 2009 | 11:39 PM
75F350's Avatar
75F350
Has to go on the pump discharge side, so this will be between the pump and the carb.
Almost zero pressure before the pump, but should see around 6 psi after it.
Old Apr 2, 2009 | 11:46 PM
59 shorty's Avatar
59 shorty
Pickup in the fuel tank? Try running it from a fuel can instead of the gas tank.
Old Apr 3, 2009 | 12:09 AM
shameless's Avatar
shameless
took the tube off the pickup because it was kinda deteriorated. put on a rubber fuel line to the length of where the float would be on empty. after cleaning out the pickup tube of course. lol
Tyler S
Dec 26, 2014 01:20 PM
ejmaso
1947 and Older Ford Trucks
31
Oct 16, 2012 09:57 AM
church4629
May 25, 2011 05:06 PM
meangenejr
Oct 16, 2004 04:43 PM
79supercab4x4
Jan 3, 2002 01:02 AM
