Need some non-idi help
Old Jun 14, 2011 | 07:58 PM
Otahyoni's Avatar
Otahyoni
Got an 88 Mercury Grand Marquis. When you let off the accelerator (coasting to a stop and such) it dies.
The codes i got:
KOEO:54- Mid temperature switch is open constantly
82- Air diverter solenoid circuit fault
KOER: 91- O2 sensor always lean
I have no idea what the two KOEO codes mean. I'm sure it needs a tuneup, but could that be all that it needs?
Help please....this is my sisters car...
Old Jun 14, 2011 | 09:18 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Your sister has my winter beater dream car
Might wanna post this up in the 87-97 F-series forum. Same engine as in there trucks over there.
Must be an EFI 302 right?
Old Jun 14, 2011 | 09:31 PM
84-6.9L's Avatar
84-6.9L
KOEO is key on engine off IIRC clean your iac motor its the bypass valve mounted on the throttle body, and check voltage at the circut, if you have a hayes manual for your 86 it should have some efi info in it with voltage readings and such.
Old Jun 15, 2011 | 06:25 AM
Otahyoni's Avatar
Otahyoni
Will do John, and yes, EFI 302.
84, I have a chiltons for my 86. I'll see what it says.
eg1031
Aug 19, 2013 08:55 PM
grldben
Aug 4, 2013 08:45 PM
Otahyoni
Jun 15, 2011 05:54 PM
texasyakfisher71
Aug 3, 2010 01:30 PM
el conquistador
1983 - 2012 Ranger & B-Series
13
Apr 27, 2004 10:53 PM
