P132B CODE
P132B CODE
Can a bad or lazy VGT solenoid cause a P132B code? I just recently had the turbo cleaned and the VGT solenoid replaced about 3 months ago. The truck is a bit sluggish at take off. Is there anyway to check the solenoid to see if its bad? Thanks for any help.
<!-- / message -->
<!-- / message -->
<!-- controls -->
You absolutely do NOT want to try and clean the solenoid.
You must have an 03 motor in your truck? Do you know when the last time it was flashed? Usually this code is related to an aftermarket intake. Other things you can do: pull the EBP sensor, check it for corrosion, and clean the EBP tube. Check the map sensor rubber tube from passenger side of the intake manifold to the map sensor and make sure the tube and nipple in the manifold are clean. Do you drive the truck rather conservatively?
p132b..........simple!
<TABLE width="95%"><TBODY><TR><TD>2003 PCED On Board Diagnostics 6.0L Diesel
</TD><TD align=right>SECTION 5: Pinpoint Tests
</TD></TR><TR><TD></TD><TD align=right>Procedure revision date: 06/15/2009
</TD></TR></TBODY></TABLE>
<HR><TABLE cellSpacing=0 width="95%"><TBODY><TR><TD>KA: Turbo Charger System Performance
</TD><TD width="25%" align=right> KA: Introduction </TD></TR></TBODY></TABLE>
<HR>
KA1 PRELIMINARY DIAGNOSIS
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">For DTC P132B, P2262 or P2263, GO to KA2 .
For all other DTCs, REFER to Section 4 Diagnostic Trouble Code (DTC) Descriptions. </TD><TD width="50%">GO to KA2 . </TD></TR></TBODY></TABLE>
KA2 CHECK THE MANIFOLD ABSOLUTE PRESSURE (MAP) AND BAROMETRIC PRESSURE (BARO) SIGNAL ACCURACY
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA3 . </TD><TD width="50%">GO to Pinpoint Test E . </TD></TR></TBODY></TABLE>
KA3 CHECK FOR INPUT SENSOR BIAS
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA4 . </TD><TD width="50%">REFER to the appropriate pinpoint test to continue sensor diagnostics. </TD></TR></TBODY></TABLE>
KA4 CHECK THE TURBOCHARGER OPERATION BOOST
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA5 . </TD><TD width="50%">GO to KA6 . </TD></TR></TBODY></TABLE>
KA5 CHECK THE TURBOCHARGER OPERATION BACK PRESSURE
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA7 . </TD><TD width="50%">GO to KA6 . </TD></TR></TBODY></TABLE>
KA6 CHECK THE CHARGE AIR COOLER, AIR INTAKE AND EXHAUST SYSTEMS FOR LEAKS
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPAIR the leaks. REFER to Section 4, Performance Diagnostic Procedures if a driveability concern exists.
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">GO to KA8 . </TD></TR></TBODY></TABLE>
KA7 CHECK THE VGT ACTUATOR STABILITY
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">The turbocharger system is operating correctly. REFER to Section 4, Performance Diagnostic Procedures.
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">GO to AK7 . </TD></TR></TBODY></TABLE>
KA8 CHECK THE OPERATION OF THE VGT ACTUATOR
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA9 . </TD><TD width="50%">GO to AK2 . </TD></TR></TBODY></TABLE>
KA9 CHECK THE VGT VANE OPERATION
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">CARRY OUT the Turbocharger Reconditioning General Procedure. REFER to the Workshop Manual Section 303-04D Fuel Charging and Controls — Turbocharger. </TD></TR></TBODY></TABLE>
<HR>
******** language=JavaScript src="/renderers/utils/logging_omniture.js">*********> ******** language=JavaScript src="/renderers/utils/include_wsm_yesorno.js">*********>
<HR>
- Key ON, engine running.
- Using the gauge bar, access the exhaust pressure sensor port.
- Access the PCM and monitor the, EGR DC, RPM and VGTDC PIDs.
- Access the PCM and control the EGR DC, RPM, and VGTDC PIDs.
- Increase the commanded engine speed to 1,200 RPM using output state control. The calibration may limit the actual RPM between 1,150 and 1,200 RPM.
- Decrease the EGR duty cycle (EGR DC) to 0%.
- Decrease the VGT duty cycle (VGTDC) to 0%.
- Record the exhaust pressure from the gauge bar.
- Increase the VGT duty cycle to 85%.
- Decrease the VGT duty cycle to 0%.
- Key in OFF position.
- Disconnect the exhaust pressure (EP) sensor from the tube.
- Connect the Rotunda Smoke Machine, Fuel Evaporative Emission System Tester 218-00001 (522) or equivalent to the EP sensor tube.
- Fill the exhaust system with smoke until smoke is present at the exhaust pipe.
- Plug the exhaust pipe.
- Pressurize the exhaust system with 20 psi regulated air.
- Disconnect the hose from the MAP sensor.
- Inspect the MAP sensor hose and manifolds for damage, leaks, restrictions, and correct routing.
- Connect the Rotunda Smoke Machine, Fuel Evaporative Emission System Tester 218-00001 (522) or equivalent to the MAP hose.
- Fill the air intake system with smoke.
- Plug the air filter box.
- Pressurize the air intake system with 20 psi regulated air.
- Check the air intake and exhaust systems for leaks.
- Install the VGT actuator in the turbocharger assembly.
- Remove the pipe plug from the top of the VGT actuator housing, located near the oil supply tube.
- Apply an index mark on the internal valve cam follower (tip of the actuator).
- Access the PCM and control the VGTDC PID.
- Increase the VGT duty cycle from 20% to 85%.
- Check the internal valve cam follower for movement at each step while increasing the duty cycle.
<HR>
http://www.flatratetech.com/downloads/diesel_8.pdf This helped me through my p132b issue.
