P132B CODE
Old Jun 14, 2011 | 06:40 PM
stitch89's Avatar
stitch89
P132B CODE
Can a bad or lazy VGT solenoid cause a P132B code? I just recently had the turbo cleaned and the VGT solenoid replaced about 3 months ago. The truck is a bit sluggish at take off. Is there anyway to check the solenoid to see if its bad? Thanks for any help.
<!-- / message -->
<!-- controls -->
Old Jun 14, 2011 | 08:19 PM
2006powerstroke90's Avatar
2006powerstroke90
I hear you do more damage to the VGT solenoid by trying to clean them than anything.
Old Jun 14, 2011 | 09:39 PM
npccpartsman's Avatar
npccpartsman
You absolutely do NOT want to try and clean the solenoid.
You must have an 03 motor in your truck? Do you know when the last time it was flashed? Usually this code is related to an aftermarket intake. Other things you can do: pull the EBP sensor, check it for corrosion, and clean the EBP tube. Check the map sensor rubber tube from passenger side of the intake manifold to the map sensor and make sure the tube and nipple in the manifold are clean. Do you drive the truck rather conservatively?
Old Jun 14, 2011 | 09:55 PM
vloney's Avatar
vloney
p132b..........simple!
<TABLE width="95%"><TBODY><TR><TD>2003 PCED On Board Diagnostics 6.0L Diesel
</TD><TD align=right>SECTION 5: Pinpoint Tests
</TD></TR><TR><TD></TD><TD align=right>Procedure revision date: 06/15/2009
</TD></TR></TBODY></TABLE>
<HR><TABLE cellSpacing=0 width="95%"><TBODY><TR><TD>KA: Turbo Charger System Performance
</TD><TD width="25%" align=right> KA: Introduction </TD></TR></TBODY></TABLE>
<HR>
KA1 PRELIMINARY DIAGNOSIS
Are any DTCs present?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">For DTC P132B, P2262 or P2263, GO to KA2 .
For all other DTCs, REFER to Section 4 Diagnostic Trouble Code (DTC) Descriptions. </TD><TD width="50%">GO to KA2 . </TD></TR></TBODY></TABLE>
KA2 CHECK THE MANIFOLD ABSOLUTE PRESSURE (MAP) AND BAROMETRIC PRESSURE (BARO) SIGNAL ACCURACY
Does the MGP PID match the actual gauge pressure?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA3 . </TD><TD width="50%">GO to Pinpoint Test E . </TD></TR></TBODY></TABLE>
KA3 CHECK FOR INPUT SENSOR BIAS
Are the BARO and MAP PIDs within specifications and is the MAP and BARO PID values within 10 kPa (1.5 psi) of each other?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA4 . </TD><TD width="50%">REFER to the appropriate pinpoint test to continue sensor diagnostics. </TD></TR></TBODY></TABLE>
KA4 CHECK THE TURBOCHARGER OPERATION BOOST
Is the MGP PID below 3 kPa (0.44 psi) at 0% VGT duty cycle and above 6 kPa (.87 psi) at 85% VGT duty cycle?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA5 . </TD><TD width="50%">GO to KA6 . </TD></TR></TBODY></TABLE>
KA5 CHECK THE TURBOCHARGER OPERATION BACK PRESSURE
  • Key ON, engine running.
  • Using the gauge bar, access the exhaust pressure sensor port.
  • Access the PCM and monitor the, EGR DC, RPM and VGTDC PIDs.
  • Access the PCM and control the EGR DC, RPM, and VGTDC PIDs.
  • Increase the commanded engine speed to 1,200 RPM using output state control. The calibration may limit the actual RPM between 1,150 and 1,200 RPM.
  • Decrease the EGR duty cycle (EGR DC) to 0%.
  • Decrease the VGT duty cycle (VGTDC) to 0%.
  • Record the exhaust pressure from the gauge bar.
  • Increase the VGT duty cycle to 85%.
  • Decrease the VGT duty cycle to 0%.
Is the exhaust pressure gauge reading below 5 kPa (0.73 psi) at 0% VGT duty cycle and above 50 kPa (7.3 psi) at 85% VGT duty cycle?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA7 . </TD><TD width="50%">GO to KA6 . </TD></TR></TBODY></TABLE>
KA6 CHECK THE CHARGE AIR COOLER, AIR INTAKE AND EXHAUST SYSTEMS FOR LEAKS
  • Key in OFF position.
  • Disconnect the exhaust pressure (EP) sensor from the tube.
  • Connect the Rotunda Smoke Machine, Fuel Evaporative Emission System Tester 218-00001 (522) or equivalent to the EP sensor tube.
  • Fill the exhaust system with smoke until smoke is present at the exhaust pipe.
  • Plug the exhaust pipe.
  • Pressurize the exhaust system with 20 psi regulated air.
  • Disconnect the hose from the MAP sensor.
  • Inspect the MAP sensor hose and manifolds for damage, leaks, restrictions, and correct routing.
  • Connect the Rotunda Smoke Machine, Fuel Evaporative Emission System Tester 218-00001 (522) or equivalent to the MAP hose.
  • Fill the air intake system with smoke.
  • Plug the air filter box.
  • Pressurize the air intake system with 20 psi regulated air.
  • Check the air intake and exhaust systems for leaks.
Are any leaks present?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPAIR the leaks. REFER to Section 4, Performance Diagnostic Procedures if a driveability concern exists.
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">GO to KA8 . </TD></TR></TBODY></TABLE>
KA7 CHECK THE VGT ACTUATOR STABILITY
Do the VGTDC and MGP PIDs remain steady at all of the RPMs?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">The turbocharger system is operating correctly. REFER to Section 4, Performance Diagnostic Procedures.
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">GO to AK7 . </TD></TR></TBODY></TABLE>
KA8 CHECK THE OPERATION OF THE VGT ACTUATOR
Is any internal valve cam follower movement present when the VGT duty cycle is increased?
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to KA9 . </TD><TD width="50%">GO to AK2 . </TD></TR></TBODY></TABLE>
KA9 CHECK THE VGT VANE OPERATION
  • Install the VGT actuator in the turbocharger assembly.
  • Remove the pipe plug from the top of the VGT actuator housing, located near the oil supply tube.
  • Apply an index mark on the internal valve cam follower (tip of the actuator).
  • Access the PCM and control the VGTDC PID.
  • Increase the VGT duty cycle from 20% to 85%.
  • Check the internal valve cam follower for movement at each step while increasing the duty cycle.
Is any internal valve cam follower movement present in each step when the VGT duty cycle is increased?
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">CARRY OUT the Turbocharger Reconditioning General Procedure. REFER to the Workshop Manual Section 303-04D Fuel Charging and Controls — Turbocharger. </TD></TR></TBODY></TABLE>
<HR>
******** language=JavaScript src="/renderers/utils/logging_omniture.js">*********> ******** language=JavaScript src="/renderers/utils/include_wsm_yesorno.js">*********>
Old Jun 14, 2011 | 10:27 PM
craftsmangary's Avatar
craftsmangary
I had this code before and it was a intercooler tube came loff the IC. =no boost
Old Jun 15, 2011 | 04:10 PM
stitch89's Avatar
stitch89
Yes its a 03 engine, I have cleaned the EBP sensor and tube they were not that dirty.
I havent checked the map sensor rubber tube yet. I drive the truck every day and pull a 24ft trailer about 4 to 5 times a year. Dont haul anything that often. Thanks for the info......
Old Jun 15, 2011 | 04:19 PM
stitch89's Avatar
stitch89
Wow, sounds like I need to find a mechanic. The other codes are P006A P0401 P132B P2269. EGR is blocked. Not sure what mass air correlation means.
Old Dec 25, 2011 | 11:16 PM
dukie1877's Avatar
dukie1877
So what was the problem?
Old Jan 3, 2012 | 02:57 PM
critterf1's Avatar
critterf1
Inquiring minds want to know
Old Jan 10, 2012 | 07:45 AM
dkhollins's Avatar
dkhollins
Im sitting in the same boat on my 03 right now. I've had the P006A P0401 codes since doing my EGR delete a year ago, but the P132B just popped up a couple weeks ago out of the blue while trucking down the highway.
It starts fine, runs fine, not sluggish, but need to determine the cause.
Old Jan 10, 2012 | 08:53 AM
dukie1877's Avatar
dukie1877
well Ill update my results I had my turbo rebuilt and problem went away. Not like that helps but my turbo was crap and now it works if the truck would run itwould be a good turbo LOL
Old Jan 10, 2012 | 10:13 AM
cartmanea's Avatar
cartmanea
P132B is a turbo code, but can be caused by EGR not doing what it should. Your block off kit is causing it all if you don't have a tuner to properly delete the EGR.
Old Jan 10, 2012 | 11:34 AM
raptor131's Avatar
raptor131
Originally Posted by dukie1877
well Ill update my results I had my turbo rebuilt and problem went away. Not like that helps but my turbo was crap and now it works if the truck would run it would be a good turbo LOL
you had me laughing, that is just so sad it is funny.
Old Jan 10, 2012 | 01:51 PM
dukie1877's Avatar
dukie1877
Lol glad I can amuse you
Old Jan 10, 2012 | 05:05 PM
doubledee715's Avatar
doubledee715
http://www.flatratetech.com/downloads/diesel_8.pdf This helped me through my p132b issue.
