Thump at stop/start
Old Jun 14, 2011 | 03:20 AM
robert_l_ross's Avatar
robert_l_ross
Question Thump at stop/start
I saw a reference to this problem but cant find the thread.
My 2000 Ex has a thump that happens when slowing to a stop, right as the vehicle comes to a complete stop but just before the front suspension "lifts" after the initial "dive" that happens when you apply the brake.
If I ease up on the brakes as I slow (like doing a "limo stop" where you can't feel that you have stopped moving), the thump happens at the instant I apply the throttle to start moving again. I can even make it happen when applying moderate brake to stop but lifting off the brake while still rolling forward.
I can't tell if it is suspension related, but I would think it is since I don't feel it when moving and letting off the throttle or putting my foot into it, but that isn't a diagnosis I know.
Ay ideas what to look for?
Old Jun 14, 2011 | 10:02 AM
LivingLarge's Avatar
LivingLarge
Does it sound/feel like it's from the front or rear?
Usually, if from rear... The slip yoke needs service. This is very easy to do or you can take to ford.
I had this done at dealership last year for $99.
Hope this helps.
Old Jun 14, 2011 | 10:36 AM
robert_l_ross
Hope this helps.
Hard to tell, as you feel it through the frame, not the steering wheel or pedals. I initially thought front end since it coincides with the dip the nose takes when you apply the brakes.
Old Jun 14, 2011 | 10:57 AM
LivingLarge
Front end, would be process of elimination, front swaybar end links could cause the thumping. Even a body mount can cause a thumping...
In my case From what you discribed it was my slip yoke.
If it were a body mount, chances are high that you would notice it under your feet when in drivers or passenger seat... Please note this usually starts off as a creaking sound and by the time it gets to thumping a few years would have passed.
Old Jun 14, 2011 | 10:47 PM
robert_l_ross
I did have a small creak under my feet but after removing the seats and console to run sime wiring, it went away. As I took the seats out I noticed the bolts were not what I would call tight by any stretch of the imagination, so I chalked that up to loose seat bolts. This is definitely not the seat bolts. Will get some grease and get dirty doing the slip yoke job. Seems a small/cheap preventative step that just might fix the issue.
Old Jun 14, 2011 | 11:04 PM
Forest's Avatar
Forest
One simple thing to look at are the shock mounts. Simply use a big box-end wrench or a break-over and socket and check the torque on the lower mount bolts.
I know...it may be only a 10% chance of being the problem...but I had this problem one time and it sounded like my ball joints were falling out.
Old Jun 15, 2011 | 05:59 AM
LivingLarge
Good luck, post your findings.
Old Jun 18, 2011 | 01:27 AM
Irikumi's Avatar
Irikumi
I have the same thing on my Ex... I have been told by the Ford Mechanic that the rear slip joint on the rear drive line is a common source of the noise, it would cost about $100 to have it pulled apart and re-greased up and "might" solve the problem... so not sure its worth the trouble to "maybe" fix the issue, I just keep driving it and it doesn't seem to get worse so **** it. I have 106K on my Ex... if it blows up oh well.
Old Jun 18, 2011 | 08:36 AM
LivingLarge
Quote from Irkumi, "I have 106K on my Ex... if it blows up oh well."
Sir, you have a new truck!!
Old Jun 18, 2011 | 05:59 PM
wpnaes's Avatar
wpnaes
It's basically free if you do it yourself. Not at all difficult, PM me if you want a step by step with tools needed. Even if it doesn't 'need it', it's a fun job that will increase your knowledge and skills.
Old Nov 10, 2020 | 07:52 PM
Ch_se21's Avatar
Ch_se21
Did anybody ever resolve this? I am currently experiencing exactly the problem described.
Old Nov 10, 2020 | 11:05 PM
2002Ex's Avatar
2002Ex
I had the same problem. The blue "nylon" coating on the spline was worn off. That coating is essential, unfortunately. I had to buy a new drive shaft, as I could not find anywhere to have the spline recoated in this mystery blue coating.
You can try greasing it yourself as it only takes a few minutes to remove the drive shaft. Others have suggested Marine level grease.
Old Nov 11, 2020 | 10:05 AM
wpnaes's Avatar
wpnaes
https://www.amazon.com/Genuine-Ford-Fluid-XG-8-Lubricant/dp/B000NU77DA
expeditionph
May 24, 2015 07:48 PM
Raise
28
Jan 27, 2015 08:02 AM
tonefordays
Apr 5, 2014 03:04 PM
Phantom2
30
Oct 28, 2010 06:34 AM
kupiec20
Mar 31, 2010 10:28 PM
