stage II's and PHP chip
Old Jun 18, 2011 | 10:42 PM
  #31
Talyn's Avatar
Talyn
Originally Posted by deadsenator
How is this a debate? There will always be an improvement. That includes the polish. Just how much of an improvement is what is unknown.
It largely depends on what shape the heads are in originally before you know what performance impact the PnP will have. Since I've never looked inside the heads on our trucks I'll presume they have typical casting marks, rough surfaces, no valve bowls, simple valve angles, and hard corners. If this is the case, PnP will improve performance significantly.
This is especially true if someone is going for a high-lobe cam. The longer valve openings will marry up to a PnP very nicely.
How does being a forced air system have any bearing on PnP? These motors still benefit from pulling in and ridding themselves of air as fast as possible. PnP is all about pulling it in and pushing it out faster.
If I had the heads off of my truck, it'd be an automatic PnP, multi-angle valve job and I'd probably go for headers instead of those air-crashing collectors we have. I would guess at a solid 15% improvement in airflow at the very least.
The benefits of polishing are just not there with a forced induction system unless your shooting for 600+ hp.
Like check this.
I asked Joey at terminator about it.
He's running multiple 500+ hp trucks.
He does NOT port and polish.
He says its not worth the money.
I'm not saying there are No benifits to it, but cost vs what you get, it could be better spent elsewhere than the polishing.
Best thing to do would be a nice valve job.
Old Jun 19, 2011 | 06:56 AM
  #32
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
There are many opinions on PNP like William said.
The 7.3 have really thin walls and to do a 'traditional' PNP you'll grind through and have junk heads.
So just a light clean up in theory would help, but with the turbo pushing the air the result is negligable gain in air flow.
Yes, every bit helps, but only if you yourself will do a very light PNP job and not have to pay for it. The minimal gains don't show hp gains on a dyno and it's not worth paying $$$ to get it done.
I don't know of any high hp motors with any head work other than springs, fire rings, and maybe valves.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jun 19, 2011 | 08:56 PM
  #33
Shaun lindmark's Avatar
Shaun lindmark
Originally Posted by rideracelivemx7
shaun lindmark, hes on here every now and then, more so on PSN. me and him tossed them in 2 hours flat start to finish and runs great, again jim your the man. but he saw my truck and wanted 2s immediately. its pulls HARD. wish i had an auto now..
Haha yea steve you wish you had an auto till it blows then you would be wanting the 5 speed again lol Im just waiting for mine to blow. I have a hard time keeping my foot out of it lol These injectors with php tunes are awsome no complaints at all. Cant wait to get my pump from joey this week because i set the check engine light pretty easy.
Old Jun 21, 2011 | 02:40 PM
  #34
deadsenator's Avatar
deadsenator
Okay, I was away for a coupla days and went and read more. That's always a good thing. My experience of PnP is from the motorcycle world. It looks like it's far easier to do there. I used to get airflow gains over 30% on some of the worst cast heads. The best factory head I saw was only a 7% gain after the PnP.
The take I have now is that a port and polish still helps, but the gains are dependent on the person doing the job and will still only amount to a small percentage gain. I have not been able to find hard numbers anywhere. The only numbers I could find were 4-5psi drop in turbo boost needed. This is a good thing, since you are making the same power with less boost. But it still only sounds like a 10% airflow increase or less (WAG).
Nothing that I read steered me away from the presence of a turbo making any bit of difference about a PnP being any less significant. It might alter the shapes of things somewhat, but either forced or drawn, air still has to flow. Just don't ruin the swirl.
Doing the PnP on the PSD is a tough job. Primarily access, the cast material being so tough to work with, and the risk of boring through to the other side like you guys mentioned. There are folks out there with CNC machines to do much of the work, but you'd still need to follow up by hand.
So, I would not remove the heads to do this work, but if I had my heads off, I would probably do some port cleanup myself. Nothing too serious with the snazzy valve job. Doing the work would save the overall expense of a PnP job.
Who makes headers for these things? Does anyone have any experience with them? I'll go read more.
Old Jun 21, 2011 | 03:59 PM
  #35
coreylasalle's Avatar
coreylasalle
ss or ceramic coated
7.3l Tubular Manifolds
i dont know anyone who has em though
bass-n-fire
19
Feb 27, 2015 11:40 AM
DanielT28
62
Feb 20, 2014 11:26 PM
kyle j
Sep 19, 2012 11:41 PM
jchosler
22
Feb 28, 2010 10:46 AM
redone1
Jul 12, 2009 12:31 PM
