axle swap
I had a 22' TT and I towed it behind both a long bed reg cab F-150 and a short bed reg cab F-150 and while the long bed handled it without a problem, the short bed was borderline nightmarish. I can't even begin to imagine how nerve-wracking it would be to put behind something with an even shorter wheelbase.
BTW I never said "heavy crosswinds".
I towed a trailier with no problem that my friend was having a heck of a time towing in his long bed F150. A Bronco was designed to tow because of the short distance from the hitch to the axle. Look at a semi. It has short wheelbase and more importantly, no distance from hitch to axle. (fifthwheel)
Of course, that doesnt change the fact that a Bronco only weighs 5000-6000 lbs.
Wind is going to be an issue no matter what you are towing and what you are towing with. Even semi drivers will tell you that.
Then that stupid CV joint in the driveshaft. F150s don't have it? Dunno about 80s+, but my 78's driveshaft and U-joints are like twice the size of my Bronco's, its frame is also more reinforced and nevermind the frontend. Might be a 78 vs. 1990 thing though?
Either way, I know that boat threw that GMC Safari all over the place, I couldn't break safely, etc.. it was a 2000 with 80k miles on it. Hooked it up to my Bronco and it was like it wasn't even there, no sway or anything. It's not some little old trihaul either, it's a big dual axle trailer with a Searay Seville sitting on it.
and for those of you towing 26' trailers in F150s, stop endangering me on the interstate. I don't care how tough you think your truck is, try to pass someone else doing the same thing and you'll understand why I absolutely hate people who either overload their trucks OR don't drive at safe speeds. Even mowers with two ZTRs go for 3/4 or 1tons (might be a tad overkill). Just because you CAN doesn't mean you SHOULD.
One more time if I have already said it. the Bronco is a GREAT vehicle, but I'm much more concerned about frame strength and body weight more than anything else when towing. There are a few spots where I could see my frame snapping in two if I try to push it too hard. The amount of flex I get offroad is sickening.. It's great for towing REASONABLE loads, but when you're pushing your 1/2 ton trucks well above what they should be towing, then sure, maybe the Bronco is a tad less safe.
and for wheelbases? Cmon, we're ONLY comparing to 1/2ton trucks which are made for towing and hauling. Again, against an Expedition, Excursion, F150, F250, F350, F450 and all similer vehicles, the Bronco isn't a tow vehicle.. but for NORMAL needs, it's not just adequate, it's flat out good. Throw on the stiffer lift springs that we just about all do and it becomes even better, and we all know spring rate and engine power have more to do with towing than the wheelbase of all things.
I'd trust my lifted Bronco over any stock pre-96 F150 any day of the week to pull anything within reason.
I was courius about frames. The F250 I got my D60 brackets from was .270" thick. My 92' Bronco's frame is .210" thick. I believe the F150 is identical to the Bronco.
The Bronco, Expedition and F150 are all 1/2 ton trucks.
Gerystreak, The F150 is lighter then a Bronco on the rear wheels. (unless you fill the bed.) My point about the semi is the closer your hitch is to the axle, the less the trailer can sway the tow vehical. I'm not sudjesting a Bronco will tow better than a F250 or F350. But I'll take the Bronc over the F150 any day.
https://www.ford-trucks.com/forums/1...ton-truck.html
As everyone has been saying for years and years, a Bronco makes a lousy tow rig. The wheelbase is just too short. You guys can argue with me until you're blue in the face, but it doesn't change the laws of physics. Vehicles with shorter wheelbases don't tow as well as vehicles with longer wheelbases.
Amen, I'll drink to that!! What was this thread about again?
