Sponsored by: Auxito
View Poll Results: Fuel pump change, which is easier?
Drop the tank.
61.54%
Pull the bed, change the pump from above.
38.46%
Voters: 13. You may not vote on this poll
Pulling fuel pump, which is easier?
Old Jun 13, 2011 | 04:34 PM
blue2golf's Avatar
blue2golf
'99 F150XL 2WD. 4.6 V8 auto, regular cab, 163,000 miles. Looks like I need to change my fuel pump. Question, which is easier: drop the tank or pull the bed off and change it from above? (I have access to a tractor with a front end loader.)
What do you think?
Old Jun 13, 2011 | 07:26 PM
Ultramagdan's Avatar
Ultramagdan
You won't need the tractor unless you want to. A few guys can easily pick it up and move it off.
Old Jun 13, 2011 | 08:42 PM
blue2golf's Avatar
blue2golf
Hey there. It'll just be me and my step dad...and his tractor. It'll make life a whole lot easier if that's the method we use.
Old Jun 13, 2011 | 10:46 PM
93 mix 'n match's Avatar
93 mix 'n match
unless its a chevy or rusted bad, then just drop the tank.
Old Jun 15, 2011 | 08:07 PM
blue2golf's Avatar
blue2golf
Thanks for the input guys. Looks like I'll be pulling the bed. I'll let you know how it turned out.
Old Jun 15, 2011 | 08:13 PM
93 mix 'n match
why would you do that? you're gonna have to replace all the bolts for the bed... is it that hard to take out 4 bolts to drop the tank?
Old Jun 15, 2011 | 09:15 PM
blue2golf's Avatar
blue2golf
Replace all the bolts for the bed? I hadn't heard about that one.
As for the tank, I figured I'd just try pulling the bed to see what happened. If that doesn't work, I can drop the tank.
Still, I am grateful for your input. What are your concerns about the bed?
Old Jun 19, 2011 | 09:31 AM
blue2golf's Avatar
blue2golf
My step father and I decided to drop the tank instead of pulling the bed and it was a bear! We had to remove the drive shaft to give us room to work. Luckily, we didn't break off any electrical connections, but we did replace the rubber vent hoses. They were falling apart in our hands.
The good news is the AirTex fuel pump went in perfectly and runs fine. My truck has been having restart issues on hot, scorching days, the same as a couple of other guys here. I'm waiting on another 90 degree day to test it out.
Old Jun 19, 2011 | 12:01 PM
93 mix 'n match
the stock bed bolts rust easily. and they are torx head bolts, so its impossible to take them out after they've aged. so they need to be ground out and replaced. but im glad you got it out and fixed. does your truck have the 4x4 package with the big skid plate under the tank?
Old Jun 20, 2011 | 07:01 PM
blue2golf's Avatar
blue2golf
Naw, 2WD only. The only thing we had to remove to access the tank was the driveshaft.
Old Jun 20, 2011 | 07:04 PM
blue2golf's Avatar
blue2golf
Had a nice hot 90 degree day here in Evansville IN, so I took the truck for a spin to test for restart issues.....restarted fine! I'm thinking this was the silver bullet.
Thanks for chiming in with the advice fellas.
EMT
Jan 28, 2010 07:02 PM
e.alleg
Mar 7, 2009 01:19 PM
Texas Mad Man
Jan 25, 2009 05:20 PM
tjc transport
Dec 25, 2008 02:15 PM
kawa
Nov 18, 2007 07:29 AM
