Vacuum
Old Jun 12, 2011 | 08:45 PM
georgiaboy6279's Avatar
georgiaboy6279
Vacuum
What is the best way to find out if u have a vacuum leak. Believe that is my problem.
Old Jun 12, 2011 | 09:03 PM
McCormick's Avatar
McCormick
With the engine running, spray carb clean where you suspect you may have a leak. When the engine revs up you found it. Spray around the upper and lower intake gaskets to check for leaks there.
Old Jun 12, 2011 | 10:03 PM
danr1's Avatar
danr1
A hand vac pump is handy for all the vac lines and the various vacuum modulated devices, can be had fairly cheap too.
Myself I use a garden hose to check for intake gasket vac leaks, work with fairly slow flow of water working from back to front low to high with someone watching tail pipe for steam.
Steam from tail pipe = vac leak. Its easy to narrow down the exact point of the leak provided you control the flow of water rather then flood over the engine with it all in one shot. No need to go to that extreme anyway, if its sucking air you will see steam as a result with small amounts of water flowing over a given spot/area.
stevieray
17
Mar 22, 2011 10:42 PM
idahocrewcab
Jan 12, 2011 01:19 PM
Fasterhorses
1997 - 2003 F150
Jun 30, 2005 08:46 PM
kermit
Apr 18, 2004 11:35 PM
351 power
28
Jan 15, 2004 11:38 PM
