blower resistor pig tail
Old Jun 12, 2011 | 07:58 PM
00GT's Avatar
00GT
98' ranger 3.0 does anyone know where to get a new pig tail for the blower resistor except the dealer? I replace the resistor today and the plug is rusted and melted.
Old Jun 13, 2011 | 06:04 AM
pawpaw's Avatar
pawpaw
Salvage yard maybe????
Old Jun 13, 2011 | 06:15 AM
Dan Robertson's Avatar
Dan Robertson
I cut the melted connector off and put individual connectors on each wire. I saved the old connector so that I could determin which wire went where. I did that about 2 or 3 years ago and havent had a problem with it since.
Old Jun 13, 2011 | 07:48 AM
tomw's Avatar
tomw
Dan, I hope you covered the terminals with some sort of insulator as those would be exposed with full battery voltage.
There are three sources, dealer, boneyard, and possibly some web sites, such as:
Automotive Electrical Connector Pigtails, Terminals, Tools and More
I have them in my bookmarks as:
repair pigtails & connectors for cars & trucks
tom
Old Jun 13, 2011 | 03:32 PM
Dan Robertson
I did, I used the insulated style.
Old Jun 13, 2011 | 07:02 PM
Phinxter's Avatar
Phinxter
I cheaped out and cut the wires off, then crimped spade type connectors and plugged them into the resistor. I also packed it full of dielectric grease, works.
Old Jun 14, 2011 | 05:02 AM
00GT's Avatar
00GT
Thanks for the replys.. I checked around and autozone can order one for $20 I think I might just cut off and put some ends on it like suggested.
Old Dec 27, 2011 | 09:35 AM
virtualbong's Avatar
virtualbong
Can anyone provide some images of the items I would need to purchase to do it the cheap way, i.e. cut the wires and connect them individually?
Old Dec 27, 2011 | 04:30 PM
Phinxter's Avatar
Phinxter
Just use the ones available at any parts store, or even walmart sells em. Xscorpion FS10BP 10 Gauge Platinum-Plated Female Spade Terminals
Old Dec 30, 2011 | 12:11 PM
tomw's Avatar
tomw
Go here:
https://www.ford-trucks.com/forums/1...r-catalog.html
See if you can find a pigtail connector to match. You can then solder and heat-shrink wrap the repair and have good faith that it will work for the life of the vehicle and NOT cause melted 'stuff' because of poor conductivity... You should see the melting that occurs in some headlight switches because of poor connections. And you get no warning that they are heating up.
tom
Old Jan 1, 2012 | 09:34 PM
p3x's Avatar
p3x
Had the Same Issue
Went to replace the Resistor with the harness fused to the removed unit. Bought a pig tail at Car Quest for around 13.00 as I remember. Also had the inboard bolt/screw head stripped. Oh what fun...
tcoker79
Escape & Escape Hybrid
Jul 22, 2018 10:27 AM
Tominky
2009 - 2014 F150
Jun 10, 2017 03:51 PM
William Mark Brown
19
Dec 29, 2015 08:30 PM
William Mark Brown
Dec 6, 2015 04:00 PM
2002sport
Oct 23, 2010 11:01 AM
