Anyone know the part number? Mine was extremely corroded. I put a new resistor in and 2-4 settings work now but 1 is still dead. The connector is in really bad shape and I need a new pigtail for it.
Any chance of you disconnecting the battery and cleaning the contacts/terminals with electronic cleaner and a pick or small file? I would try that first before trying to splice in a new connector.
The one I posted the link to looks to be the correct connector. Any parts store should be able to cross reference it if you don't feel like ordering it and waiting.
Rockauto was OOS and the local salvage yards are short on Ford trucks. Advance Auto had one in stock and I had a Speed Perks reward so I bought from them along with some weatherproof connectors. My hope is to swap it out this weekend since it's supposed to be in the upper 40s.
Replaced the resistor yesterday. It was beyond corroded but the plug was good. Those screws were not designed for my sausage fingers to get to! Took a lot longer to change than expected (about an hour) between getting the screws out and the connector off. The plug wasn't corroded but it hadn't been disconnected in 13 years so it was stubborn to say the least.
Unless speeds 2 and 3 are almost identical it did not fix my problem. I'll have to do some more circuit tracing to see where I can go next. Regardless the resistor was in bad shape and was due for replacing anyway. At least I've ruled something out.
