ATS intake hat o ring?
Old Jun 12, 2011 | 04:37 PM
snaponprofile's Avatar
snaponprofile
Anyone have the O-ring for ats hat(part number)?!
thanks.
Old Jun 12, 2011 | 06:44 PM
oreocreaming's Avatar
oreocreaming
if you cant find one, theres a make your own O ring kit you can buy. its a roll, you just cut off where you want it, bond the ends together and you got a custom O ring
Old Jun 12, 2011 | 06:46 PM
oreocreaming
HEATING ELEMENT GASKET KIT, MAKE UR OWN O RINGS ON SITE | eBay
Old Jun 12, 2011 | 07:23 PM
snaponprofile
ok, I think a guy on OB might have it. But I'll check into that if not.
Old Jun 12, 2011 | 07:29 PM
David85's Avatar
David85
I got one from a local hydraulics shop. Just measured one that was about right and it stretched slightly to rest on the intake manifold. He said he might also be able to get Viton if needed but so far the plain one is holding fine.
Old Jun 13, 2011 | 12:11 AM
wreckinball's Avatar
wreckinball
pretty sure it isnt an oring, the ford part i saw a while back, sorry no part number, was a flat piece which makes sense being the two pieces of metal are flat as well. oh wait do you mean the one that goes inside the neck of the hat that mates to the turbo or the one that is for the intake manifold?
Old Jun 13, 2011 | 04:24 PM
tecgod13's Avatar
tecgod13
I'll second that the one from the intake hat to the manifold is flat, but its still called an o-ring (flat o-ring..) In another thread someone noted that the N/A engines had a gasket under the air-filter (missing on my truck) and that a replacement could be had from any similar sized air intake (think chevy's...)
If the gasket is thick enough, it would work! or a regular o-ring that large... might be hard to find.
cadunkle
Apr 25, 2017 11:00 PM
lefty1953
Mar 17, 2017 09:06 AM
Crew-it
55
Nov 16, 2011 05:42 AM
atvtrailrider
30
Aug 13, 2011 12:02 PM
snaponprofile
25
May 23, 2011 02:34 PM
