Sponsored by: Real Truck
Truck Pulling Right
Old Jun 12, 2011 | 03:49 PM
charbaugh's Avatar
charbaugh
Truck Pulling Right
I have a 2000 F250 V10 4x4, and it has pulled to the right since I bought it in 2003. I have changed the brakes and had it aligned (multiple times in the last 8 years...), and it still pulls. Anyone have any ideas?
Old Jun 12, 2011 | 03:54 PM
Joe Bloomingdale's Avatar
Joe Bloomingdale
Check to see if the truck will drive straight while applying the brakes, you may have a pad hung up and dragging on the rotor. I had that happen on mine and realized when I did the brakes, the inside pad on drivers side was hung up and wore down way before the rest.
Old Jun 12, 2011 | 05:03 PM
pjviitas's Avatar
pjviitas
Wheel bearings
Brakes...wheel bearings...tires...
Old Jun 12, 2011 | 07:58 PM
lowbed dud's Avatar
lowbed dud
check ball joints, lower left
Old Jun 12, 2011 | 09:58 PM
badhabit1's Avatar
badhabit1
Caliper slide pins! You can change pads 10 times and it won't help. Do a search, these trucks are notorious for this.
s91Ford
Nov 28, 2011 07:37 PM
emt676
Feb 6, 2008 10:49 AM
springer9861
Mar 23, 2004 07:15 PM
steelermke
Feb 2, 2002 11:49 AM
