Windshields
Old Jun 11, 2011 | 11:23 AM
71FoMoCo's Avatar
71FoMoCo
Windshields
I know most of the panels are the same, but are the windshields exactly the same on a 1969 and 1971 F100?
Old Jun 11, 2011 | 01:21 PM
jhooch's Avatar
jhooch
I would say yes.
Old Jun 11, 2011 | 07:34 PM
68Shortbox5.4's Avatar
68Shortbox5.4
If you look in the catalogs, the windshield rubbers and trim are the same up to 79, so I would say its safe to say the windshields are too, except for tint at the top
Old Jun 11, 2011 | 07:47 PM
FECruzer69's Avatar
FECruzer69
They will all interchange from '67 through to '79. After that, the cabs were completely redesigned.
Old Jun 12, 2011 | 06:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FTE glitch...see following post.
Old Jun 12, 2011 | 06:38 AM
NumberDummy
What catalogs are you looking in to come up with this jazz?
1967/72 windshield weatherstrips are specific to 1967/72 only. Not the same as 1973/76. 1977/79 is different from 1973/76.
C7TZ-8103110-A .. Windshield Weatherstrip: 1967/72-Use without windshield reveal mouldings.
C7TZ-8103110-B .. Windshield Weatherstrip: 1967/72-Use with windshield mouldings.
The difference between 1967/72 and 1973/76 w/strips is with the 4 corners. If a 1973/76 or 1977/79 weatherstrip is used on 1967/72's, water will leak in, you may have wind noise from air rushing into the 4 corners.
The glass is the same 1967/79. The Sun Band w/shield with the extra tint on top was first offered in 1980. It can be bought in autoglass shops for earlier models.
1967/76 & 1977 before serial number O80,001 use the same w/shield reveal mouldings. 1977 from serial number O80,001, 1978/79 use a one piece plastic chrome moulding that glues on.
The above info is from the 1964/72 & 1973/79 Ford Truck Parts Catalogs.
Carpenter has this same weatherstrip info in his 1967/79 repro truck parts catalog on page 76.
Old Jun 12, 2011 | 08:36 PM
crazed87bronco's Avatar
crazed87bronco
Sorry if this is a thread Jack but since we are talking about windows are the rear windows the same 67-79? I have a 71 f250 and want to put in a sliding rear glass all the junkyards around me only have 73-79's
Old Jun 12, 2011 | 09:34 PM
Ford_Six's Avatar
Ford_Six
No, the rear window is smaller on the 67-72.
Old Jun 13, 2011 | 06:30 AM
NumberDummy
You can buy a slider for a 1967/72 from an autoglass shop.
Old Jun 13, 2011 | 12:14 PM
qman's Avatar
qman
Don't know what reveal mouldings are but I took a windshield and weatherstrip out of a 74 and put it in my 72 and all is well. No water leaks in, no air rushes through and corners are all good.
Old Jun 13, 2011 | 09:26 PM
NumberDummy
Ask yourself this: If the weatherstrips are the same, why would Carpenter and every other repro parts sellers and the Ford truck parts catalog have listings for 1967/72 only weatherstrips?
The simple answer is, they are not the same. May work, but not correct.
W/shield reveal mouldings (fit into groove in w/strip) will be found on Custom Cabs, Rangers and etc.
Old Jun 14, 2011 | 12:30 AM
68Shortbox5.4
As to your question about what catalogs say they are the same, LMC truck is one of them, still looking for my NPD to check, not saying you are wrong, just proving I was correct in my statement also.
Old Jun 14, 2011 | 01:06 PM
qman's Avatar
qman
I didn't say it was correct. I just said there is no water leaking in. I don't doubt your numbers, but mine works great. Here's a better question.
What are reveal mouldings?
Old Jun 14, 2011 | 01:21 PM
68Shortbox5.4
Trim around the windshield, only found on above named models
Old Jun 14, 2011 | 01:27 PM
NumberDummy
See post #11
