Modular V10 (6.8l)
MPG indicator in overhead console problem
Old Jun 11, 2011 | 08:21 AM
snapnek's Avatar
snapnek
I'm new here and I also just aquired a 2002 F250 V10 4x4 and had a problem with the speedometer not working. I took to a guy that chased down a broken wire and fixed the problem. Now the overhead console reads AVG MPG .1 and then it went to .2 and then .3, I sure hope I'm not getting .1 MPG or even a staggering .3 MPG. Can anyone tell me what if going on with the indicator? The other functions seem to be working ok. Just the MPG is wacky......
Thanks in advance!
Old Jun 12, 2011 | 07:44 PM
snapnek's Avatar
snapnek
Not even a guess?
Old Jun 12, 2011 | 07:49 PM
powerstroke72's Avatar
powerstroke72
I'll go ahead and ask the stupid question.............have you done a reset on it?
Oh, and Welcome to FTE!
Old Jun 12, 2011 | 07:52 PM
snapnek's Avatar
snapnek
Not a stupid question. I don't have a clue on how to reset it. Can you tell me how?
Thanks!!
Old Jun 12, 2011 | 07:57 PM
powerstroke72
From the owner's manual:
Press the E/M and MODE
controls simultaneously. The display
will illuminate the “AVG” indicator.
While the indicator is lit, release
both controls to reset the average
fuel economy.
You can download a copy of your manual, if you don't have one, by going here:
https://www.fleet.ford.com/maintenan...ls/default.asp
Hope this helps.
Old Jun 12, 2011 | 08:00 PM
snapnek's Avatar
snapnek
THANK YOU!!!!
Old Jun 12, 2011 | 08:04 PM
powerstroke72
You're welcome. Post back up here and let us know if it worked.
Old Jun 12, 2011 | 08:07 PM
snapnek's Avatar
snapnek
Will do. I just did it and it did reset, now I just have to drive it and check to see if it worked. Will post the results.
Thanks!!
Old Jun 12, 2011 | 08:09 PM
powerstroke72
Excellent! Keep us posted.
Old Jun 16, 2011 | 05:41 PM
FireFighter12105's Avatar
FireFighter12105
Not to hijack your thread but I also am having the same problem except my entire console keeps going out and will only come back on when it decides to.
Old Jun 16, 2011 | 08:58 PM
SDV10's Avatar
SDV10
You may have a soldering issue. I believe there is a fix posted in the how to's on doing it. I have done it for my friend who has that option on his truck and it is easy and works! You have to have a fine hand or some may say steady. Oh yeah, a soldering iron is a must also.
90pioneer
Mar 13, 2013 09:24 PM
djdrexler
Aug 1, 2012 02:00 AM
3504x4
Jun 22, 2010 01:06 AM
Tazzmann
Oct 23, 2007 08:58 PM
WrangleMomma
Sep 7, 2002 06:24 PM
