tranny options?
Old Jun 9, 2011 | 10:42 PM
benreal83's Avatar
benreal83
tranny options?
im building a 54 ford customline, im going to be using a ford 300 straight 6 but im totally new to straight 6 motors and have no clue what tranny bolts to them.. i searched around on here and google and only got up grade ideas new 5 and 6 speed converts, im just lookin to get the thing rolling, would like to have a 5 speed but on super important.. if some of you ford lovers could shoot me a few model numbers of trannys that would just bolt up im be soooo thankful, thanks in advance guys happy motoring
Old Jun 9, 2011 | 11:45 PM
85e150's Avatar
85e150
Welcome to FTE!
The 300 uses the same bell pattern as the SBF, 289-302/351w.
What kind of trans do you want?
A ZF or Mazda truck trans would not have great ratios for a car.
A T5 can be adapted to that engine, and would have more car friendly ratios.
An AOD automatic would simplify your installation greatly.
What axle ratio do you have?
Info:
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
T5 Swap, T5 Conversion, Mustang T5 Swap, Auto to Manual Transmission - FordMuscle
Ford Mustang: Mustang Tech: Transmission and Drivetrain: Borg Warner T5 Transmission data
AOD:
TCI - Ford AOD, AODE and 4R70W
Old Jun 9, 2011 | 11:58 PM
benreal83's Avatar
benreal83
Ok thanks and i dont know bout the rear ratio gotta do some more home work
Old Jun 10, 2011 | 12:29 AM
85e150's Avatar
85e150
Hemmings has a good rep afaik, but as with everything, "trust, but verify":
Hemmings Motor News: 1954 Ford Mainline, Customline and Crestline
Rear axles are said to be 3.31 with the automatic, 3.90 manual trans, and 4.10 with the manual + OD trans.
Old Jun 10, 2011 | 12:45 AM
benreal83's Avatar
benreal83
Its a manual with over drive so 4.10s i guess huh? What tranny should i go with its got a big bench seat so a top shift would work better that a tail shifter if that helps narrow it down, and thanks so much for the help man im really greatful
Old Jun 10, 2011 | 03:43 PM
sufferingant's Avatar
sufferingant
I believe the M5OD would have great ratios for a car, and they're very cheap.
The 300 I6 shares the bellhousing with the rest of the small block fords (302 "5.0" and 351W) so anything that will bolt to either of those will bolt to the I6.
4.10s might be a little low for highway cruising, but it would sure add some pep around town.
Old Jun 10, 2011 | 04:23 PM
85e150's Avatar
85e150
The 3.91 first with the 4.10s and car tires isn't going to work very well in a car.....
Old Jun 10, 2011 | 04:27 PM
sufferingant
T5's from mustangs aren't much better, looks like a 3.35:1 first gear is behind the 5.0s. I think with a regear to 3:55 would be great for a city cruiser, and a 3:08 would do great on the highway.
YMMV
Old Jun 21, 2011 | 03:23 AM
benreal83's Avatar
benreal83
The cars got a 3 on the tree and had a straight 6 in it ( i was told 232) its the origanal 6 from 54, will a 300 mate to the this tranny? I talked to the previous owner and he tells me the tranny worked great
Old Jun 21, 2011 | 02:22 PM
85e150's Avatar
85e150
The 300 bell is going to have a "butterfly" pattern. Your trans is the old square pattern. It is sometimes possible to drill the bell to make the old pattern work. You will have to eyeball that one. Pics here show both patterns on the right side trans so you can see the difference. Also, depth needs to be checked.
Toploader Imposters
Old Jun 21, 2011 | 03:34 PM
AbandonedBronco's Avatar
AbandonedBronco
For a car, I would recommend an SROD transmission. They're only weakness is their aluminum casing, which tends to break when off-roading and putting the tranny through truck oriented tasks.
However, they're great for a car. Actually, they're a beefed up car transmission from the Mustangs. May even be able to find a Mustang version.
They're incredibly light weight and usually smaller than other transmissions.
1st: 3.25
2nd: 1.92
3rd: 1.00
4th: 0.71
Old Jun 21, 2011 | 03:58 PM
benreal83's Avatar
benreal83
What kinda cars/trucks did they come in?
Old Jun 21, 2011 | 04:02 PM
AbandonedBronco
I believe with cars they started sometime in the mid 70s. Trucks either 79 or 80. Both were discontinued in 83.
The nice thing about for you is they are mechanical clutches instead of hydraulic if you don't want to mess with that sort of thing.
You can identify them because you have to push the shifter down to go into reverse (at least on the truck one that I know of.)
Old Jun 21, 2011 | 10:46 PM
85e150's Avatar
85e150
The pic in the link I posted is the iron cased, side shifted model. These are based on the '60s performance toploader. The previous post is talking about a variant of these, the SROD--Single Rail Over Drive. The case looks the same, but is aluminum. The shifter sits on a turret and is connected via a tube. Pic is first up here:
Domestic Truck Tranny Guide
SRODs were found in Mustangs, Grandads and other similar cars in the late '70s to the early '80s. The truck versions were found in F100/150 in the late '70s to 1986 in one form or another. My '85 E150 had the iron box.
IMO if you can make your 3 and OD work, that's what I'd stick with. There are some advantages to the 4 speed box, but again, imo, they aren't worth losing the originality of your 3 and OD set up.
broford1
Apr 21, 2017 09:35 AM
gfburke
27
Jun 16, 2015 08:56 AM
erick wireman
Mar 8, 2015 11:56 AM
85-f150
24
Apr 2, 2010 08:45 PM
Mr. N
May 7, 2008 03:56 PM
