Box switch 74
Old Jun 9, 2011 | 12:43 PM
sledge1992's Avatar
sledge1992
Box switch 74
Hi guys,
Quick question.....How hard is it to switch a truck box from a 1974 f100 to a 1974 f250. Will it bolt right up? What am i looking at for problems? Thanks...you guys know your stuff!
Old Jun 9, 2011 | 04:08 PM
RunninD's Avatar
RunninD
The only remaining issu is if your F250 is a 4X4 (highboy). That's the switch I just did, If yours is a 2wd the switch will be mostly painless. all bolts will hypothetically line up and all wiring and fuel connections. I say hypothetically, because well there were several plants and lots of years of production and wear in there!
If you're playing with a Highboy, then all of the above will NOT be the same.
*First, the bed bolts will NOT line up! the frame rail on the Highboy is narrower, there are several posts dealing with the difference and options, gusseted tabs welded to the frame seemed to me to be the easiest
**Second, the fuel necks & components don't even apply unless you fab in a tank of your own. (I used a poly fuel tank out of an '85 F250 IDI which fits between the rails perfectly and then modded the brackets to cinch it down.)
***Wiring should be the same, barring the fuel stuff. Hope this helps.
There are other more in-depth posts on this site, but since I just did the same exact swap, I figured I'd chime in!
Old Jun 10, 2011 | 05:22 PM
sledge1992's Avatar
sledge1992
RunninD,
thanks for your response! Mine is a highboy and thought I read somewhere that the frame rails would be different. Thanks
load hog
Apr 3, 2014 09:10 AM
AmongHidden
May 18, 2012 07:07 AM
sodly
May 16, 2012 09:58 PM
mroberts91
Oct 19, 2010 11:31 PM
ford to the bone
Apr 26, 2010 07:37 AM
