grease fitting balljoints
Old Dec 27, 2005 | 11:05 PM
MENESLIS's Avatar
MENESLIS
Hey guys, i'm looking to replace both upper and lower balljoints on my truck. Is there any aftermarket balljoint with grease fittings for the lower balljoints (if there is where can i purchase a pair). For the upper balljoints can i replace them individaully or do i have to replace the whole control arm?
Old Dec 28, 2005 | 09:39 PM
98expeditionXLT's Avatar
98expeditionXLT
I just completed replacement of the lower balljoints with Moog balljoints which came with the 90 degree zerk fittings. My only suggestion is to screw the fitting into the balljoint before pressing the ball joint to the lower control arm, to be certain that the threads are good, as I had a little trouble with the threads on one balljoint. These were purchased at a local independent auto supplier who since sold out to Advance Auto Parts.
Old Dec 28, 2005 | 09:42 PM
98expeditionXLT
Sorry about not answering completely. The upper ball joint is part of the upper control arm assembly and it needs to be purchased as an assembly and I could not find one with grease fittings. Moog didn't have it and neither did TRW. You will need to plan on a front end alignment also if you replace the upper control arms.
Old Dec 29, 2005 | 07:20 PM
pdqtimetrialer's Avatar
pdqtimetrialer
Is there anyway to add grease fittings to the stock ball joints?
Old Dec 30, 2005 | 10:14 PM
98expeditionXLT
There is no worhwhile way that grease fittings can be added to the factory ball joints. Best bet is to replace the ball joints when worn with greasable ball joints.
Gerby Dutchy
2009 - 2014 F150
Oct 17, 2014 12:15 AM
BruceJeremy
Oct 14, 2010 01:10 PM
jimmc
1978 - 1996 Big Bronco
Sep 20, 2004 09:24 PM
butchf250
Oct 26, 2003 06:47 PM
